Changing sparkplugs F150 Triton Texas Edition 2007 - Ford Truck Enthusiasts Forums
Old 03-23-2008, 07:36 PM
guitarbug guitarbug is offline
guitarbug is starting off with a positive reputation.
Any tips on changing my spark plugs on the f150 2005 Texas Edition 8 cylinder. I have about 100k and truck starts and seems to run fine, except i have noticed lately that my idle is around 5 to 6 where it use to idle around 8? This is more so when I am in traffic and come to a stop in gear and it seems to lower to 5. It has only stalled on me once when I came to a sudden stop in a turn ? Any help would be great! Thanks for having me as a member! PS, I always said I would never join a club that would have me as a member, lol...
Old 03-23-2008, 10:01 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
welcome......check out the forums and you'll probably find more help in the 2004-2008 forum. You'll also find out that spark plugs can be a real nightmare on here.....alot of people have them break off in the heads....
Old 03-23-2008, 10:13 PM
Thanks Ryan! Yea, I am starting to have a Malox Moment reading about this nightmare! Thinkingabout not even changing them now. Truck is running good enough for now, lol..
Old 03-24-2008, 02:02 AM
Ryan50hrl's Avatar
better to do it now though and not wait for it to get worse......
Old 03-24-2008, 02:57 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
sounds like your plugs need some TLC...best of luck
Old 03-24-2008, 09:08 AM
db_tanker's Avatar
db_tanker db_tanker is offline
db_tanker is starting off with a positive reputation.
most Texas Editions, like mine, have the 4.6 and won't have any real issues with the spark plugs. It was a 5.4 issue and has been, as some of the actual Ford employees around here have stated, addressed.
All you should do is to take care to A) don't be too rough with the COP's and B) make sure not to knock anything off into the cylinder chambers.
Mind you, there ARE some TE's running around with 5.4's and all you really need to do is just look under the hood. Is the air-cleaner ON the engine or by the drivers side fender? By the fender? 4.6 On the engine? 5.4
Hope this helps!
D
Old 03-24-2008, 10:51 AM
Thanks! Are you talking about the air filter ? Mine is a rounded one that is in a tubular thing coming across the top of the engine but kinda towards the drivers side.
Old 03-24-2008, 11:06 AM
d.g.bowen d.g.bowen is offline
d.g.bowen is starting off with a positive reputation.
It's not too bad of a job, should be well under 2 hours. Here's a couple tips - change the wires too. The Ford wires start to arc by the time they have around 75,000 miles on them. You can use a short section of fuel line tubing to make this job easier. Once the plugs are loose, you can push the fuel line down over the plug to make getting ot out of the hole easily. Use the tubing to put the new plug in and to start it threading as well. I always use dielectric grease on both ends of the wires as well. The back couple are tough, but if you have a range of extensions, breaker bars, and knuckle joints for your socket set it's not really that bad. If you lack the proper tools, you'll have a bear of a time. Good luck!
Old 03-24-2008, 11:09 AM
Quote:
Thanks d.g.!
Old 03-24-2008, 03:27 PM
jmizell49 jmizell49 is offline
jmizell49 is starting off with a positive reputation.
A friend of mind had the broken plug problem at 100000 mile. Took his truck to a local mechanic shop for tune-up. They were not aware of the plug problem and broke two plugs. Had to wrecker truck to Ford dealer to fix problem. $1000 to get broken plugs out.
Old 03-24-2008, 03:31 PM
db_tanker's Avatar
Quote:
what you describe is the 4.6 air filter.
And these engines use COP's. Coil on Plug ignition systems.
Still might want to use a bit of dielectric grease on the tips of the plugs that go into the COP's.
to be honest, when you get your plugs from the parts house, get you a chilton's manual. that way you can have a decent enough reference there at your fingers when you are doing it.
D
Old 03-24-2008, 06:47 PM
Tylus's Avatar
if you're not mechanically inclined, I vote that you just pay a shop to do it...if you have the 4.6, the plug change is extremely easy for any shop to do in under 1 hour.
better safe than sorry IMO
Old 03-24-2008, 07:10 PM
Thanks guys! I never thought I would have to join a online forum to change dang spark plugs!, lol...I may give this a try, will keep you posted! Crossing my fingers!
86 F150 300-6 YFA Idle Speed Control danintexas 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 07-11-2014 04:18 PM
attention to all Texas Chapter Members 75Three90 Texas Chapter 45 02-18-2014 04:47 PM
Texas Edition? 41Clay 1997 - 2003 F150 39 10-16-2012 07:48 PM
2010 Brakes are touchy K_F150_Texas 2009 - 2014 F150 13 03-28-2011 08:22 PM
2009 Ford F150 Texas Edition track 2009 - 2014 F150 8 07-16-2010 05:05 PM
Tags
2004, 2005, 2007, 46, edition, engine, expedition, f150, ford, plugs, replace, review, spark, texas, triton, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
