replacing ignition.. need help
today my ignition finally got to the point where it would not turn at all with the key in it and when i tried to turn it forward the key snapped off inside of it. the ignition will NOT turn any at all, will not go to run position or anything. so i know that your supposed to have it in run position to push in the pin that holds it in so you can replace it. i also know that you can drill the ignition out where the key inserts in order to get the pin to release it. are there any other ways of getting the ignition out of this truck? Also, where can i get a new one? thanks guys
I have done a crap load of cyclinders and I usually take a good snap-on flat head screwdriver and gently persuade the ignition to turn on. You have quit alot of room to play with just don't drill too deep if you do drill.Then do as you said, push release pin. Autozone should have it . I don't know if they stock our trucks but I have bought alot of different ones there. Good luck
RBerry9511
02-07-2020 04:31 PM
BillC1009
08-12-2012 07:53 PM
Beast12
Electrical Systems/Wiring
07-30-2004 10:16 PM
