1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bad ball joint?
Old 03-23-2008, 09:03 AM
GLF250's Avatar
GLF250
GLF250 is offline
Bad ball joint?
I was adding grease to the various fittings under my truck when I noticed on the passenger side some rusty water coming out. I believe this is from the upper ball joint. I gave it a few extra pumps with my grease gun to try and get the brown looking grease out but I am wondering if this is a sign of a bad ball joint?
Old 03-24-2008, 08:48 AM
ironmine's Avatar
ironmine
ironmine is offline
Well .... water/debris does not belong inside a joint. Something has failed, and has allowed it to enter the joint .... to some degree. I would say your ball joint is in the process of failing. Maybe I'm wrong.
Movement in the joint shows a bad ball joint. Jack it up and look for movement in the joint. It can sometimes take a lot of force to show movement in a joint that is just starting to fail .... a six-foot pry bar putting pressure on the wheel/tire.
Good luck.
Old 03-24-2008, 09:17 AM
i eat hybrids's Avatar
i eat hybrids
i eat hybrids is offline
Is your truck squeaking with u turn the tires?
rock2610d
03-29-2016 04:14 PM
4.9LOldFordTruck
01-20-2016 04:38 PM
fightlivefree
01-05-2016 10:33 PM
FordTruckChuck
1997 - 2003 F150
10-27-2015 04:01 PM
spinella
19
04-29-2013 10:52 AM
Quick Reply: Bad ball joint?
