Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-23-2008, 08:11 AM
fdude64 is starting off with a positive reputation.
oil pressure issue
i have a 79 f-250 4x4 with a mid 70s 460, my question is whee does the oil pressure sending unit get it supply from? does the oil go from pump to sending unit to filter? or pump to filter then sending unit? the reason i am asking is my oil pressure reads on h (factory guage) all the time while running. thought maybe filter is stopped up.
__________________
the difference between the men and the boys is the size of their toys
http://www.youtube.com/watch?v=xR273bcYSzQ
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-23-2008, 08:21 AM
hotrodmerc's Avatar
hotrodmerc is starting off with a positive reputation.
I wouldn't trust the factory gauge. Mine always reads L and I have checked with a wet gauge that reads 80PSI.
__________________
Tony
  #3 (permalink)
Old 03-23-2008, 08:33 AM
i am getting ready to go out and change the filter and see if that makes a difference. i was thinking about installing a mechanical guage, can i remove te sending unit and install the new guage line there?
__________________
  #4 (permalink)
Old 03-23-2008, 01:31 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
Quote:
You need to test the gauge and the sender. Find the oil pressure sender and ground the wire with the key in the on position. Should show full scale deflection. Remove the wire from ground and gauge should show zero. If it does replace the sender. I doubt the filter is the issue as the sender is after the filter. I can't think of an engine with the pressure sender before the filter.
__________________
Bear 45/70
Gimp Racing
  #5 (permalink)
Old 03-23-2008, 06:08 PM
hotrodmerc's Avatar
Yes you can remove the sender and install the wet gauge connection in the same hole.
__________________
Tony
  #6 (permalink)
Old 03-23-2008, 06:14 PM
Bear 45/70's Avatar
Quote:
You can install a "T" and have both hooked up too.
__________________
Bear 45/70
Gimp Racing
  #7 (permalink)
Old 03-23-2008, 08:39 PM
ok thanks guys. next weekend i will get the guage and put it in.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
