How much does a stock f250 1968 Weigh
Originally Posted by bigTJrox
I bought a 1968 f250 off a freind 9 month s ago but the owner prior to him must have torn the tag off i looked all over the internet for f250 specs but not everybody is as smart as u guys probably is please help
Bill, FYI 3800 lbs is about what a 100 will weigh, I would think 4500 would be closer.
Big T, Don't know how important it is, but look around for a local bulk feed store, truck stop, maybe take a load of junk to the land field or scrap dealer. Most of those kinds of places have truck scales. You can find out exactly what it weighs.
John
John
Originally Posted by jowilker
Bill, FYI 3800 lbs is about what a 100 will weigh, I would think 4500 would be closer.John
The shipping weight for a F100 8' Styleside w/a 6 cylinder engine is 3,505 lbs.
on
I drove my '68 F250 CS across a set of scales shortly after I got it. The bed was empty, about 1/2 full of gas, FE engine/NP435 tranny and it tipped the scales at around 4800 as I recall. I was surprised, didn't expect it to be that much...
Can't believe the frame would weigh 1K more than an F100, there must be a few other things that account for the extra weight over John's truck. I should probably hit the scales again to check it sometime soon.
The above differences would prolly add an additional 300 lbs of weight over a like F100.
Where's the extra 700 lbs?
It all has to do with the "Section Modulus."
The depth and construction of the frame rails.
A 1968 F100 with a 131" wheelbase C channel frame has a section modulus of 3.06 inches.
A 1968 F250 with a 131" wheelbase C channel frame has a section modulus of 3.98 inches.
A 1968 F250 with 4WD and the F350, both with a 131" wheelbase C channel frame has a section modulus of 5.57 inches.
Not only are the frames different depths, but the F250 2WD frame (for example) uses more steel, and hence...is of thicker construction.
Size matters.
texasblue55
23
07-20-2021 06:06 PM
1968 F250camper
15
10-29-2017 08:21 AM
Xand17
06-14-2017 04:28 PM
RENA1608
12-14-2016 02:47 PM
