Faulty Spare Tire Cable
Has anyone had their spare tire fall out from under their truck? I have and it happened just after I left the interstate in my 99 F-150. When I came to a stop I felt a bump and thought the car behind me hit my truck but it turned out the cable holding the spare up broke (clean brake at the wedge) and tire fell out. I'm just glad this didn't happen while I was still on I-40 doing 75 MPH-scary! To the best of my knowledge, the spare tire has never been removed until the day the cable broke?
Mine had before i bought my truck. It had broke right the end, so i went to tractor supply, and bought like 4 cable clamps. Since i didnt have the org. end piece i had to make it out of a piece of angle iron. Then i put all those clamps on the end of the cable.
Its been about a year now since i fixed it and nothing has happened(i check it about every oil change).
mine fell apart on my '01 luckily it was when I was changing it and not when I was driving. I had to look at the cable dangling under my truck most of the winter, once it got warm enough to get under there and check it. I found the housing split open and the cable jumped the track and the powdered metal for the handle to seat into split apart as well.
A few bolts, removed it, and threw it in the trash. Appears to be one of the worst parts Ford ever put on.
Originally Posted by jimm66
Where do you get your new units. Ford dealer? Does it just bolt on?
When mine broke the cable at the end, i just got some cable clamps to fix it.
The cable didnt break on mine, but the reel did. One day last winter my brother was raising the spare tire with the hand crank and all of the sudden he felt a, "POP" and you could no longer raise or lower the spare tire.
I got a new one for $60 from the dealer.
My father works for a Ford dealer and he told me that its fairly common for these to fail and that most people just cut the cable and throw their spare tire in the bed.
I thought about doing this, but I use my truck for hauling firewood, so putting the spare tire in the bed greatly reduces the amount of wood I can fit in the bed.
If I had an extended cab I might have just put the spare tire inside the cab, but being that my truck is a regular cab thats not really an option.
Its pretty to scary to think what could happen if that cable suddenly snapped and your spare tire hit a pedestrian.
Originally Posted by FTE/PARTS-GUY
99 F150
CABLE ASSY SELL $65.64 SHIPPING $9.50
HAVE ONE IN STOCK
Ed
HAVE ONE IN STOCK
Ed
When I try to crank it down (or up ) the handle slips out real easy. I have to push in very hard to keep it in the slot. Don't know if it's worn or full of dirt. I did try to hose it out and it worked a little easier but not much. So is the carrier the whole deal, cable and all? 4 bolts to replace it?
