Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-22-2008, 10:38 PM
savage_racing is starting off with a positive reputation.
Canadian Econoline VINs
I dragged a 66? outta a farmers field the other day.
Does anyone have a breakdown for canadian(oakville) vins
Any info would be greatly appreciated
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-22-2008, 11:17 PM
6931190L-220043A is what I got stamped in the serial no portion
  #3 (permalink)
Old 03-22-2008, 11:24 PM
66gpw's Avatar
66gpw is gaining momentum as a positive member of FTE.
I do not recognise those numbers. Look on the back right corner of your van/truck. There should be a metal brace going across the corner right in front of the tailight. This will have the serial number for the vehicle. Get me that and we can probally break it down.
The serial number tag should be on the drivers door with info also about engine , axle, paint color. That number you posted is unknown to me.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
86 F150 Exploere XLT Ext cab
66 Merc 1Ton Flat deck
78 F250
  #4 (permalink)
Old 03-22-2008, 11:34 PM
I will have a look and see what i can find in the back but that is what is stamped.
keep in mind that this truck was built in oakville, canada.
I can email you a picture of the tag from inside the door if you would like.
  #5 (permalink)
Old 03-22-2008, 11:58 PM
66gpw's Avatar
You have to PM me or post the tag in your gallery which you can upload your pics of your new ride.
Just go to usercp and click on this and it goes to edit gallery and signatures and so on. Here you can post pics of your trucks.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #6 (permalink)
Old 03-24-2008, 02:11 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
Quote:
It's a 1965 Econoline.
After 1965, Canada uses the same VIN and Warranty Plate US trucks do.
The following is from the General Information Section ~ 1964/72 Ford Truck Parts Catalog ~ Canadian Built Vehicles.
6: Engine Code: 6 Cylinder (the info doesn't say which one).
93: Body Type Code: Station Bus
11: Series Code: 1965 Econoline
90: Wheelbase = 90"
L = Left Hand Drive
220,043 = Numerical Sequence of Assembly (Canada)
A = Gross Vehicle Weight Range: 0 to 6,000 lbs.
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
  #7 (permalink)
Old 03-24-2008, 11:07 PM
AWESOME, you are the man!
now can you explain the whole 11=1965 portion
  #8 (permalink)
Old 03-25-2008, 05:05 AM
Ford Parts Guru
From the General Infomation Section (page 35) of the 1964/72 Ford Truck Parts Catalog ~ 1965 Canadian Built Vehicles.
"The fourth and fifth digits of the serial number indicate the truck series."
"The following chart lists these codes and truck model which they represent."
The number 11 represents all Econolines.
The number 10 represents all 1/2 ton pickups / the number 35 represents all one ton pickups, etc.
I left something out of the last post. The numerical sequence of assembly.
The first serial number for the following 1965 Canadian built trucks: B500/700; C550/600; E100; F100/750 is: 195,001 = which means your Econoline (220,043) is a 1965 model.
__________________
  #9 (permalink)
Old 03-25-2008, 09:44 PM
thanks muchly
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
