Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-22-2008, 08:22 PM
mmuenchow is starting off with a positive reputation.
rocker arm oil deflector clips
Do I need oil deflector clips on my 400 ford stock set up? I just purchased new rocker arms with bolts and the fruncrum from melling . They did not include any clips. I had a set of heads from another car so I had a valve job done and am in the reassembly part of the job. thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-23-2008, 02:50 PM
mustang81 is starting off with a positive reputation.
The oil deflector clip is the baffle. Early style stamped-steel rocker arm have a seperate baffle. If your rocker is bent-over tab at the pushrod-end you don't need the baffle.
  #3 (permalink)
Old 03-23-2008, 03:27 PM
Cool
Quote:
No oil deflector clip under the bolt. So off to the parts store i must go.
Thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
