You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
ive been experimenting with stuff to make methoxide, and i used some sort of draino and traxxas rc car fuel(methanol with some crap in it) and got some weird stuff on the bottom of my bio, its about as dark as maple syrup, and the bio is about as dark as apple juice, oh and im doing the dr.peper style of making it, ... im new to this so any help is appriciated, thanks,
it has been washed once, and i think i did it right...
__________________
Justin
94 F-250 Turbo Diesel, 7.3L IDI, E4od, 4x4, long bed, ext cab, pyrometer, ATS boost gauge, IP turned up 2 flats, Straight pipe
93 F-250, 7.3L IDI, E4OD, 4X4, long bed, ext cab, straight pipe... almost.
Reason: add more info
RC fuel has nitromethane and oils in it along with the methanol. might be getting some other precipitates setting out. how long has it set? I had to let mine mine set a couple days before all the glycerine settled out. decant the stuff off the bottom and try washing it and see if it clears up....
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
1994diesel, CAUTION! You may have accidentaly created explosive salts by combining nitromethane with sodium or potassium hydroxide in the methoxide mix. According to the material safety data sheet at this link http://www.jtbaker.com/msds/englishhtml/n5740.htm it is possible to create explosive salts that are very sensitive to heat and pressure once dried. I hope someone on here that is a trained chemist will give a knowlegable opinion on this matter. Good luck. Jim
oh wow!!! jeez i hope didnt, and i let it settle for a few days but the glycerin didnt solidify like it usually does it just turned into a weird chocolate substance... i am also letting it dry for a day in between washes, so i will try that, thanks guys for the help, i will be careful about what i do.
__________________
Justin
Drano will not work properly. Drano contains Sodium Hydroxide, Sodium Nitrate, Sodium Chloride, and Aluminum!! Adding Methanol and Nitromethane can cause some nasty chemical compounds to form, including explosives.
Never, Never, Never use Drano!!!
What you should use for small batches is Red Devil Lye. Red Devil is pure Sodium Hydroxide. Nitromethane is a No,No too.
Please dispose of this hazardous mixture before someone gets hurt!!!
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
