can you take the cats off - Page 2 - Ford Truck Enthusiasts Forums
Old 03-25-2008, 02:44 PM
Peter94's Avatar
Peter94 Peter94 is offline
Peter94 is gaining momentum as a positive member of FTE.Peter94 is gaining momentum as a positive member of FTE.
I bet you didnt even remove the cat. Any vehicle after 1996 has downstream 02's to monitor the performance of the catalytic converter. I bet they were just resonators to reduce noise. In any case DO NOT remove catalytic converters. It does no good. The reason they got such bad flack is because when they came out, they used pellets coated platinum and other rare metals, which would cause an exhaust restriction. If you look at the material out of a cat today, it is a honeycomb type material, that DOES NOT restrict exhaust flow. Anyone who says they cut off their cat and gained 20 HP is on crack, that is unless they have some engine problems, and had a clogged cat.
Think of it like this, if Ford is engineering a vehicle to compete with Dodge, Chev, Toyota, they WILL make the cat big enough to handle all the exhaust the engine can put out.
Old 03-25-2008, 03:22 PM
Kevin_JG Kevin_JG is offline
Kevin_JG is starting off with a positive reputation.
removing the cats does nothing performance wise, adds more sound, but when you run through town with your exhaust and a cop pulls you over thinking you have striaghts, and then puts a smog tester up to your exhaust.. youll think twice about removing them..
Old 03-25-2008, 05:09 PM
dadirtydogg dadirtydogg is offline
dadirtydogg is starting off with a positive reputation.
[QUOTE=Peter94]I bet you didnt even remove the cat. Any vehicle after 1996 has downstream 02's to monitor the performance of the catalytic converter. I bet they were just resonators to reduce noise. In any case DO NOT remove catalytic converters. It does no good. The reason they got such bad flack is because when they came out, they used pellets coated platinum and other rare metals, which would cause an exhaust restriction. If you look at the material out of a cat today, it is a honeycomb type material, that DOES NOT restrict exhaust flow. Anyone who says they cut off their cat and gained 20 HP is on crack, that is unless they have some engine problems, and had a clogged cat.
well i clearly never said that i gained any power only that it increases the volume of the exhaust. there are two cats, THEN THE DOWNSTREAM O2 SENSORS, as i stated before. the two rear cats are located after the sensors. i suppose they could be resonators, but everyone i've ever talked to called them cats. and from what i am told, not 100% sure so don't quote me, they are for noise reduction only. i live in alberta and cops don't have smog detectors here. so that wouldn't be an issue for me anyway. also, when i put headers on i'm going to eliminate the front two cats and put in O2 sensor simulators
Old 03-26-2008, 09:11 PM
Peter94's Avatar
Hey, I'm not trying to get on your case dadirtydogg. I'm just saying that you probably didn't even remove any emissions equiptment (cats) so you dont have to worry about getting in trouble or anything. I would have cut off the resonators too if I had nice new truck like that! My GF's mom just got an 06 F150 CC, and i'm trying to talk her into duals, lol
Old 03-27-2008, 11:57 AM
NGibbons55 NGibbons55 is offline
NGibbons55 is starting off with a positive reputation.
HEY dadirtydogg where in alberta are you from?? Im looking at taking my cats off too to make it louder, can u give me some info, I want to do it myself because the shops wont do it.
Old 03-27-2008, 05:43 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
Quote:
Take the muffler out.....it will be PLEANTY loud that way...i'm confident its as unlawful to remove the cats up by you as it is by us.....and again...theres really no benefit...
Old 03-30-2008, 12:58 AM
i'm in grande prairie... my buddy let me use his hoist and welder.... i had to drop the exhaust down to get the weld properly around the top though. was a little bit of work.... i ran my truck with no exhaust when i put my magnaflow muffler on and it was loud, but i prefer the sound with the muffler and the two cats/resonators removed
Old 03-30-2008, 09:37 PM
Brolli Brolli is offline
Brolli is starting off with a positive reputation.
y not just replace all four cats with two high flow performance cats. That should be legal on all accounts. No?
Old 03-31-2008, 03:28 AM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Quote:
yes, that is the only way to do it legally.
Old 03-28-2013, 09:25 PM
Infantryman1991 Infantryman1991 is offline
Infantryman1991 is starting off with a positive reputation.
Well done here in louisiana we like loud exhausts and there's no inspection no smog detector crap or any of that I cut my back two off true duals strait pipe with an x sounds better than duck commander duck call
Old 05-24-2013, 12:10 AM
jet04 jet04 is offline
jet04 is starting off with a positive reputation.
I took all 4 off of my 04 f150 4.6 with an x and 2 flowmaster super 40s and I travel in it from rgv to indiana and no problems
What would give me the best sounding exhaust? Jonathan Stone Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 02-16-2016 01:44 AM
460 exhaust questions Geusey 1987 - 1996 F150 & Larger F-Series Trucks 12 07-12-2014 03:03 AM
06 true dual setup MichiganHunter 2004 - 2008 F150 28 04-18-2010 11:41 PM
shorty question turbo69 1978 - 1996 Big Bronco 5 01-25-2005 01:31 AM
Want dual exhaust/must pass emissions testing Wolfman2405 Exhaust Systems 5 10-26-2003 05:33 PM
Tags
150, 2004, 46, black, cats, cut, duals, f150, ford, law, loud, magnaflow, mufflers, quiet, race, rear, remove, true
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
