anyone recomend a shop in edmonton - Ford Truck Enthusiasts Forums
Alberta Chapter Join Chapter, Leader: Puddy
Old 03-22-2008, 03:40 AM
bison77 bison77 is offline
bison77 is starting off with a positive reputation.
I'm looking for a mechanic/Shop that regularly does work on older trucks. I have a 86 super cab F-250. The front gas tank is venting gas out at the cap. if I pull over and unscrew the cap at the front tank I get about 300ml of gas puke out of the tank. I always fill the rear and use the rear tank, but it seems gas is finding it's way to the frnt tank somehow, building up pressure as the engine runs then venting. I have read alot of posts re: this.....any help would be appreciated. a good shop or private mechanic.
Thanks.......Dan
1986 F250 Super cab...
Old 03-22-2008, 11:50 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
If you post a question about the fuel tank and emissions system in the 80-86 truck forum, I'll reply with some tech info for you
Old 03-23-2008, 02:57 PM
done....thanks for your attention Dennis
Dan
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
