Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 03-31-2008, 11:15 PM
390Deep is starting off with a positive reputation.
My buddy had one in an 85 3/4 ton 4x4 with 488,000 kms on it. Leaked oil smoked and was slower than a VW hippie bus but it got awesome mileage. He beat the piss outta that thing. Never did quit.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 04-08-2008, 10:43 PM
Chevy 6.2D is starting off with a positive reputation.
Quote:
This is the craptastic reworked gas big block that GM turned into a diesel. They suck, have no power, and inf used to any degree of hard work tend to break.
Wrong.
Quote:
The 6.2 was a detroit diesel and like another person posted, did what it was supposed to. Last forever, move things, be reliable, and run on diesel. They were a little slow, but that's because they were naturally asperated. If you put a Banks turbo system on the 6.2, it makes more power than the stock 6.5 that replaced it.
Oh the the 5.7 was totally built as a diesel engine. The problems it had are very similar to the problems of the 6.0. Not enough head bolts, using torque to yield head bolts, rushing to production, not having adequately trained mechanics and a problem that it doesn't share with the 6.0 is the lack of a water separator.
Supposedly after these things were worked out the 5.7 was a decent engine, but the damage was already done.
EXACTLY.
The 5.7 is somewhat based on a gasser (because it was to be used in vehicles that were also sold with a 350 gas), but a 6.2 is not AT ALL.
  #18 (permalink)
Old 04-13-2008, 07:50 AM
IB Tim's Avatar
Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Moved to GD
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #19 (permalink)
Old 04-13-2008, 09:05 AM
origcharger is gaining momentum as a positive member of FTE.
Our 6.2 diesel always got 20-26 mpg and outlasted the Suburban it came in.
I remember an annoyance was you could not remove the rocker covers without removing the injection lines which you could not remove without removing the intake manifold. In retrospect, after looking at some of the modern diesels of today, it was easy to diagnose and work on
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #20 (permalink)
Old 04-13-2008, 02:57 PM
spence13e's Avatar
spence13e is starting off with a positive reputation.
they might have done well in the GM pickups, but not HMMWV's. they were junk there, all of ours broke continuously when we had them over seas, but they were beat the hell up when we got them.
finally got outfitted with 1114's with the 6.5 turbo and for pushing 14 to 15000 lbs they have a LOT of guts to them, plus the brakes work surprisingly well. we had relatively few problems with them when we got 'em.
__________________
Ryan
2004 F-250 6spd Crew Cab 4x4
3.73LS, 235/85R16
K&N Cold Air Intake
Magnaflow 4" Cat Back
  #21 (permalink)
Old 07-04-2008, 07:32 AM
Louis Amsler is starting off with a positive reputation.
The 6.2 was a good little engine. They were around for the first low sulfur diesel fuel and their cheap inj pumps suffered. The cranks didn,t break, but around 250000 miles, the harmonic damper falls apart, the engine vibrates a lot and the snout breaks off, pretty quickly. They are slow, but reliable otherwise. I drove mine for 20 years and still liked it. It's too bad they got confused with those converted 350's. By the way I likr my Ford better.
  #22 (permalink)
Old 07-04-2008, 10:07 AM
Pocket's Avatar
Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.Pocket has a great reputation on FTE.
My parents owned an old 84 Suburban with the 6.2L. Guaranteed the trans would break every year. Nothing like driving down the highway and see the rear glass covered in trans fluid. I lost count of how many times it happened.
The engine blew with less than 150K miles on it, cracked the block. My dad found a replacement block, took the heads in and had them reworked, put it together and sold it. That was one of the most problematic vehicles they owned. Trans couldn't handle the amount of torque at such low RPM's. Engine was gutless and could barely get out of it's own way at sea level. At altitude, you were lucky to make it up a mountain pass at 20 mph, and that was without a trailer behind it.
__________________
Curtis
2002 F-250 PSD
Best time: 15.3 @ 86.8 MPH at Bandimere - 9/10/08
  #23 (permalink)
Old 07-04-2008, 10:22 AM
preppypyro's Avatar
preppypyro has a great reputation on FTE.preppypyro has a great reputation on FTE.preppypyro has a great reputation on FTE.preppypyro has a great reputation on FTE.preppypyro has a great reputation on FTE.
I used to drive one as a farm vehicle/company truck for this one farmer I worked for. It was an 81 chevy half ton 2 wheel drive 6.2 with a 3 speed standard with overdrive. The thing got amazing fuel economy, and with the lighter truck, and manual transmission it could move along really nice.
It had around the 600k mark on it for mileage, and I was young and didnt drive it nice at all. We had to change glow plugs on it in the few years I drove it, and that was it.
The rest of the truck basically rusted right out from underneath the motor, but its still used to this day, as a farm truck, running the original engine.
__________________
$Sheldon$
2003 F-250 supercab shortbox 4x4 lariat
~Everythings legal man as long as ya dont get caught~
Quote:
Originally Posted by FTE Ken View Post
You can fix ignorance, you can't fix stupid.
  #24 (permalink)
Old 07-04-2008, 03:13 PM
stormyrider is starting off with a positive reputation.
My dad had one of the 6.2's in a suburban. It lacked power but a Banks turbo kit rectified that issue. The suburban sucked, lots of issues with water leaks around the rear doors, side doors and automatic transmission don't hold up well with a diesel.
__________________
2000 F250 4 x 4 77,000 miles conventional cab longbed
six speed manual transmission.
AIS intake, 4" turbo back Magnaflow S/S exhaust
inlet & outlet pyrometers & boost gauge
  #25 (permalink)
Old 07-04-2008, 03:16 PM
My dad had one of the 6.2's in a suburban. It lacked power but a Banks turbo kit rectified that issue. The suburban sucked, lots of issues with water leaks around the rear doors, side doors and automatic transmission don't hold up well with a diesel. The engine also had issues with crankcase oil leaks around the oil pan.
__________________
  #26 (permalink)
Old 07-05-2008, 12:22 AM
duffman77's Avatar
duffman77 is starting off with a positive reputation.
The 6.2 is the fuel economy king of all light duty diesel truck engines.
  #27 (permalink)
Old 09-12-2008, 08:37 PM
Heavy_Metal is gaining momentum as a positive member of FTE.
This should have been moved to General automotive discussion.
  #28 (permalink)
Old 09-13-2008, 12:47 AM
preppypyro's Avatar
Its a general diesel topic
__________________
$Sheldon$
  #29 (permalink)
Old 09-13-2008, 10:42 AM
parkland's Avatar
parkland is gaining momentum as a positive member of FTE.parkland is gaining momentum as a positive member of FTE.
I think most hummvees used a 6.5 amgeneral without a turbo.
HUmmers suck, engine wise. I was in one once, no leg room, powertrain leaves lots to be desired.
6.2's have nothing to do with 5.7's. , or DD for that matter.
6.2's and 6.5's are simply light duty engines. For light daily driving, they can last a long time. Nothing like the 7.3 IDI's or 5.9 cummins.
__________________
2002 7.3 PSD 4x4 Nothing out of the ordinary.
Quote:
Originally Posted by 6686L View Post
I nominate this Parkland guy for President. He KNOWS what is important, has his priorities straight. I mean...if...we are going to have a "pair of boobs in the White House"...at least with Parkland running the place...there will be some that are good to look at...!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
