1976 F250 Highboy Dana 44 6cf wheel hub... - Ford Truck Enthusiasts Forums
Old 03-21-2008, 09:17 PM
rcmf5525 rcmf5525 is offline
rcmf5525 is starting off with a positive reputation.
As the title states, I am looking for 2 wheel hubs for the Dana 44 HD axle. I am amazed at how hard of a part this is to find!!! Can anyone point me in the right direction???
Old 03-21-2008, 09:41 PM
If I cant find one from a '76, could I convert to a '77 1/2-'79 hub? Do they share the same size spindle/bearings? I know the locking hub is different. What would the swap take?
Old 03-21-2008, 11:20 PM
Mr.N Mr.N is offline
Mr.N is starting off with a positive reputation.
Quote:
Warn sell a new hub: 9072
I've never used these.
However the original Spicer Hubs are stronger. Best bet is junk yard search. I've seen them go for $100 and up.
Click for larger picture
Old 03-21-2008, 11:22 PM
I am looking for the actual wheel hub not the locking hub. Sorry I wasnt clear... Thanks though...
Old 03-22-2008, 07:18 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Why is it hard to find? Because in most cases, Ford only supplied the hub and rotor as an assembly.
The following number is no longer listed, but it may have been replaced.
You may want to contact Ed Olsen, his website is: ftepartsguy.com
2) D6TZ-1102-E .. Hub & Rotor Assy.
Old 03-22-2008, 05:57 PM
I know where two are, but they cost $500. Bonus you get the truck with them
Old 03-22-2008, 06:24 PM
Thanks for the link. I emailed him because the website will not search for anything pre '80. I think I will be able to use a '77 1/2 to '79 hub. They do share the same bearings. broncograveyard.com has them for $70 each. Not a bad price considering Napa sells them for $154... LOL...
Old 03-22-2008, 07:18 PM
76 & 77 are a different hub from a 78 & 79 F250. Also the 78 & 79 are a shorter axle shaft...
I've never seen the swap done...
Old 03-23-2008, 12:39 AM
I dont think the length of the axle shaft will have much to do with the size of the hub. I think that would be more in the axle tube length. The hubs share the same sized bearings. I will have to hold them side by side to see. If there is anyone out there with a hub from a 77 1/2 to 79 lying around, take a measure from race to race (bearing cup to bearing cup) and post it. I will do the same to see if there is any difference there. It has to be from the HD axle...
I have seen the '77 1/2 to '79 spindles and they look identical to the ones off the '76. You never know, I might find a new conversion from this. Replacements are much easier, and cheaper, to come by for the '77 1/2 to '79. Replacement lock out hubs are cheaper as well...
Old 03-23-2008, 01:28 PM
anyone able to get a measurement?
Old 03-23-2008, 05:57 PM
Actually it does... and it's only the outer axle stub that changes length.
From -> http://77cj.littlekeylime.com/Spicer...afts_Mr.N_.gif
76-77 part # 29508-1 & 29508-2 = 34.75" & 18.62" with outer at 10.66"
78-79 part # 660124-3 & 660124-4 = 34.75" & 18.62" with outer at 9.72"
Now take a look at the two hubs, see how the 76-77 is much thicker at the end and has a different hub? The 78-79 is much smaller.
The axle shaft from a 76-77 will not let a 78-79 hub fit the lock-out on.
I can't remember if the spindles are the same or not....
76-77 hub
78-79 hub
Old 03-23-2008, 06:29 PM
From -> http://77cj.littlekeylime.com/Spicer/graph/Dana44_Front_Axle_shafts_Mr.N_.gif
76-77 hub
78-79 hub
I see what you are saying and thanks for the heads up about stub axle length difference. Yes, the '76-'77 lock out will not fit in place of the '78-'79 lock out because they are completely different. The two hubs share the same bearings and seal. The only thing that would keep me from using the later hub would be the actual distance between the inner and outer bearing cups. Is the track on a '78-'79 shorter than the '76-'78? It appears to be with a .94" difference in stub length. I guess I will just have to try it out if I cant find a replacement set for the '76.
new wheel hubs for a dana 44hd jay_blu 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-22-2014 09:56 AM
Dana 44-6CF Help Feardeere7 Clutch, Transmission, Differential, Axle & Transfer Case 2 04-04-2014 10:57 AM
1988 F-350 D60 Wheel and Hub Assembly 9/16" Studs Part Number Mallow 1987 - 1996 F150 & Larger F-Series Trucks 3 11-11-2011 05:31 PM
dana 44 big hub Bigbruce Offroad & 4x4 4 04-29-2010 12:28 PM
Dana 44 and Dana 44 HD dhickey 1973 - 1979 F-100 & Larger F-Series Trucks 12 04-09-2001 03:15 PM
Tags
1976, 44, 44hd, 6601244, 6cf, 76, bearing, dana, f250, ford, hd, hubs, lock, replacement, size, warn, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
