Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 04-26-2008, 10:18 PM
BlueOvalFitter is starting off with a positive reputation.
Exclamation
I took my truck to the dealer today and they kept it.The tech pulled the upper plenum and the lower intake runners are coated/lined with oil and carbon! The pcv valve is very oily too.He pulled a few plugs and they were oily and carboned too! He had to call the Ford tech line to get further instructions on what to do.He thinks a baffle in the valve cover might be defective,but won't be able to go any further until Monday.
__________________
2007XL R/Cab,4.2 V6,auto
The anticipation of death is worse then death itself!
  #17 (permalink)
Old 04-30-2008, 03:36 AM
bokker is starting off with a positive reputation.
hi, after my engine rebuild when all was clean i still got the rattle when under load at cruzin speed. it was always made worse when pullng hills with a caravan being towed but playing with the throttle i could keep the sound to a minimum.
the strangest thing is, when i converted to propane gas no more death rattle!
all the info about propane use tells me that it simply masks the sound and the problem is still there. so now i have stopped thinking about it and hope all is ok. bokker.
  #18 (permalink)
Old 05-01-2008, 05:21 PM
Exclamation
Dayum,finally got my truck back today! Here is what was done;
New MAF sensor
New IMRC actuator
New pcv valve and (2) hoses
New valve cover baffle
New spark plugs
New gaskets;upper and lower intake,valve covers
New fuel filter
De-carboned upper and lower intakes
De-carboned engine;rings,pistons,valves,etc. -(3) times
Oil change
Compression test
Cylinder leak down test
I only had to pay for the fuel filter and $15.00 of gas,due to it being empty when I brought it in there Saturday!
They test drove it and it pinged very slightly,only on hard acceleration upon first moving and very slightly upon upper speeds going over big hills,overpasses,etc.They compared it to another 07 with 18k miles on it,and an 06 with 25k miles on it,and mine was much more quieter,not even close to the others!
I'm satisfied,now,but will be monitoring it closely! Actually,it runs just as good or better then when it was new!
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
