blue devil head gasket sealer - Ford Truck Enthusiasts Forums
Old 03-21-2008, 07:54 AM
AC94EXPLORER's Avatar
AC94EXPLORER AC94EXPLORER is offline
AC94EXPLORER is starting off with a positive reputation.
has anyone heard of blue devil headgasket sealer? i was thinking of putting some of that in for now till i get the head gasket fixed. i took it in to a shop for a blown head gasket check and he said it was an outside head gasket issue and told me to put the blue devil head gasket sealer in till i can afford to get it fixed. for 60 bucks it better work. water has not gone into the oil just blows out of the exhaust sitting at the traffic light. i need to make a trip to ca and back (wa) he said it will be fine once i add it. any thoughts?
Old 03-21-2008, 07:31 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Haven't heard of blue devil, but I assume it's comparable to BarrsLeak or Stop leak. Putting those types of additives into your system will cause addtional damage to the water pump, heater core, radiator, ..etc. If it's not overheating, I would drive it until you can fix it properly. I drove my 92 with a blown head gasket for over 2 years.
Old 03-23-2008, 10:10 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
Old 03-23-2008, 10:11 AM
steve(ill)'s Avatar
Old 03-23-2008, 11:03 AM
i do have bars leak but it isnt working workedfor a week then it went back to the same problem.
Old 03-23-2008, 11:11 AM
Backin72 Backin72 is offline
Backin72 is starting off with a positive reputation.
I'm really leary about these magic pills in a bottle, but I've heard good things about Steel Seal.
http://www.steelseal.com/eng/home.html
Old 03-23-2008, 02:47 PM
steve(ill)'s Avatar
AC94, were you using radiator sealer or the head gasket/ cracked head sealer?
if your using the head gasket sealer, how about leaving the stuff in the radiator for a few hours of use?
Old 03-23-2008, 03:45 PM
73f100shortbed 73f100shortbed is offline
73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold73f100shortbed is a splendid one to behold
I heard of the blue devil stuff. Hear it works really well, but have not personally tried it.
Old 03-24-2008, 02:35 PM
i do want to put some type of sealer in it before i go and im going with the blue devil cause it has no metal shavings in it. i did use the bars leak for cracked heads and blown head gasket and it seems not to work.
Old 11-30-2008, 11:59 PM
karlster karlster is offline
karlster is starting off with a positive reputation.
Blue Devil worked great for a toyota 22re that was so leaky it would hydrolock and the oil was all milky looking. I have a thousand miles on it and no issues so far.
As I understand it the stuff crystallizes as it is exposed to the gasses in the combustion chamber. It won't crystallize in the cooling system as long as it lacks the gasses that catalyze the reaction.
It has a money back guarantee and I used it on a truck that was destined to be a parts truck so I had nothing to lose.
I would say give it a try.
karl
Coolant Entering Cylinders? - Already Replaced Head Gaskets Sprucegreen Expedition & Navigator 8 06-05-2015 09:28 AM
Head gasket question skidoorulz 1961 - 1966 F-100 & Larger F-Series Trucks 9 03-31-2015 04:29 PM
Head Gasket? calisdad 1968-2013 Full Size Vans 7 01-14-2015 11:54 PM
292 Heads leaking skidoorulz Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 5 12-09-2014 09:24 PM
04 sport trac no acceleration, terr. idle mustangelite Explorer, Sport Trac, Mountaineer & Aviator 1 10-17-2012 07:34 AM
Tags
blue, bluedevil, buy, cracked, devil, drive, fix, gasket, head, leak, repair, reviews, sealant, sealer, stop, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
