Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-20-2008, 11:05 PM
Aero-fan's Avatar
Aero-fan is starting off with a positive reputation.
What's up with the odd aerostar tire size?
I was talking to the guy that inspected my van today and he said I had dry rotted tires. He then tried to sell me some of his tires but he said he didn't have any in my size and that they were a sort of outdated/oddball size. 215/75-14 was the size I believe and apparently this is an outmoded size. I guess 14 inch rims have mostly gone by the wayside in recent years. Anyway, I'm sure you guys already know this, so my question is are there any good tires for the aerostar or have many of you upgraded to 15 inch wheels and whatever wheels? Thanks...
__________________
1997 Aerostar Extended 3.0 2WD, 28K miles
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-20-2008, 11:38 PM
99f350sd is starting off with a positive reputation.
Quite a few tires made that will fit....
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..Diablo Predator
MDII Plow, 200 amp alt timbrens,Revo's
85f150, THREE 96 aero*awd 4.0 ext. 05 mountaineer V8 Awd
Lever's are cool enough for me too...LOL
  #3 (permalink)
Old 03-20-2008, 11:56 PM
You could go with the 215/70/14 they are about .85 in smaller dia. otherwise the same
Speedo will be 2 mph off.
http://www.discounttiredirect.com/di...foTireMath.jsp
Input both tires...
Dick
__________________
  #4 (permalink)
Old 03-21-2008, 04:13 AM
96_4wdr's Avatar
96_4wdr is gaining momentum as a positive member of FTE.
if you plan on keeping it, get 5 7"x15"x114.5mm 5 bolt Ford rims off Ranger/Explorer etc at your local junke auto parts emporium or new if cash is no object.
then go with 225/70/15 radial tires
the 15" rim will fit under the EXT as spare. and 15" are far easier to find on a trip in the outback traveling
toss the skiny spare, it's rotted and a road kill waiting to happen
  #5 (permalink)
Old 03-21-2008, 08:51 AM
Aero-fan's Avatar
Thanks everyone, I was thinking about the 70 series tires but would like to keep my speedo as accurate as possible. The 15" rim sounds like the best option, I'll probably use that calculator to find a 15" tire that's the same height as the original. Thanks again...
__________________
  #6 (permalink)
Old 03-21-2008, 09:18 AM
AeroPA's Avatar
AeroPA is gaining momentum as a positive member of FTE.
http://www.miata.net/garage/tirecalc.html
215/65 - 15
__________________
Doug
96 Aerostar
95 Ford Contour GL
03 Chevy Cavalier
Where are we going, and why am I in this basket?
  #7 (permalink)
Old 03-21-2008, 01:36 PM
dpier is starting off with a positive reputation.
I just got new rubber on my Aero this week. I used P205/75R14
  #8 (permalink)
Old 03-21-2008, 04:23 PM
93nighthawk's Avatar
93nighthawk is starting off with a positive reputation.
Back in '86 14" tires were the norm on most vehicles, and sense there were only minor changes to the Aero throughout those years, including the rims.
Like what has been mentioned, if you are on a tight budget, I would recomend going with to the junk yard and picking up a set of Ranger/Explorer/Bronco II rims and putting new rubber on those. I picked up a set of Explorer Slicer Rim's and put 215/65-R15's on and love them. Gives the Aero a Trucklike look and only cost me $160 bones for the rims.
Good luck with whatever you decide!
Edit: Check out this thread: http://www.ford-trucks.com/forums/65...ight=tire+size
__________________
'96 Ford Contour 2.0 I4 MTX 77k mi- Rear Ended 12/22/07
'97 Ford Aerostar AWD 4.0L v6 AT 81kmi
'97 Chevy Lumina 3.1 v6 ATX 135k mi Parents old beater, temp vehicle
Future: 2009/10 Taurus SHO, Loaded
My Car Domain
The Possum Aero-Van!
  #9 (permalink)
Old 03-21-2008, 08:55 PM
jetfiremuck is starting off with a positive reputation.
You could go the Mazda pickup route. They have a nicer different mag selection and you do not have that big ugly center cap to worry about.
  #10 (permalink)
Old 03-21-2008, 09:09 PM
What size mazda pickup route? and year if you know...
__________________
  #11 (permalink)
Old 03-21-2008, 10:05 PM
Quote:
90s-present B2000 (I think that is what it is called.) The one that is the same size as the Ranger, um, yea, well, it is a Ranger with different body clading. The door jam says built by FMC for Mazda, and almost everything in it is transplanted from the Ranger, except for decor.
__________________
My Car Domain
  #12 (permalink)
Old 03-21-2008, 10:14 PM
Would you know what size those would be.?
__________________
  #13 (permalink)
Old 03-21-2008, 10:17 PM
Rim? 14" 15" 16" and 17" sizes
Body? 1/4 ton Pick Up.
__________________
My Car Domain
  #14 (permalink)
Old 03-21-2008, 10:24 PM
The rim size? Was there only 1 size avail on these trucks.
__________________
  #15 (permalink)
Old 03-21-2008, 10:34 PM
There are different sizes availible from the mazda line, your choices: 14" 15" 16" 17" The bolt pattern is the same as the Ranger/Aero/BII/Explorer.
EDIT: And you can also choose from Mustang/Crown Vic/Grand Marque/Towncar and also Jeep Cherokee/G Cherokee. All have the same bolt patern.
__________________
My Car Domain
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
