What's up with the odd aerostar tire size?
The tire I have found I like is the All Position (Goodyear I think) 27x8.50R14LT
They firm up the ride without making it harsh, and really stabilize in corning. They dramatically improve the handling under weight. However, my van is used for work, and the rear seats are all removed, so I don't know how ride quality would be for them.
The size is only slightly larger than the largest factory tire used on the Aeros. I found it helped compensate for the inaccuracies in the speedometer. According to my GPS unit, I am going an average of 1 mpg slower than my speedometer indicates.
I bought my tires at Tire Pros.
My 1990 awd came with 215/75/14.
Just keep in mind that these numbers are NOMINAL specs, provided at the discretion of the manufacturer, and will vary from brand to brand, sometimes even among models of the same brand.
I would get the biggest tires that would fit on the rim, and not rub anything on extremes of turns and suspenion travels.
I put 6x15" ranger rims with 215/65 15's on my '97 shorty.
The rims and tires are the same diameter as the OE 14's. Speedometer is unchancged.
They look better and the tires are wider and the rims are "punched" somewhat. No rubbing or scraping. The tires are Yokohama Avids, high miliage tires.
I got the ranger rims for $25.00 apiece and the tires were $50-55 apiece from Tire Rack.
Beaned
Beaned
on
1 Post
If I were to put different size tires on my Aero, I would want them to be significantly smaller diameter so as to give a boost to the gear ratio. I have a 3.73 and a tire 10% less diameter would make it effectively a 4.10. Not sure I would like the lowering effect, but then that would aid handling. Maybe I'll do that next time I need tires.
Or easier yet, maybe I can get something like a 4.50 ratio rear end.
The Aerostar is still a truck weighing around 4000 pounds, and I don't think you want to put too small of tires on it. Also, if you have AWD, you want to make sure the front and rear tires match, or it will try to lock the center diff from the speed differences that it will interpret as slippage.
#28
96_4WDR - First, what's the PSOM? I'm assuming the computer in the dash that controls the speedo display? Second, how do you reprogram the PSOM? That'd be nice to know if I go with a differing tire size.
TallPall - That's funny you have a 3.73 and want a 4.10 rear in your aero. I have a 4.10 in my 3.0 and I'm thinking about getting a 3.73 rear for a little better mpg. Is your van a dog with the 3.73? Do you have a 3.0? Why do you want to get rid of it and go with a 4.10? Thanks...
#30
on
1 Post
