I was talking to the guy that inspected my van today and he said I had dry rotted tires. He then tried to sell me some of his tires but he said he didn't have any in my size and that they were a sort of outdated/oddball size. 215/75-14 was the size I believe and apparently this is an outmoded size. I guess 14 inch rims have mostly gone by the wayside in recent years. Anyway, I'm sure you guys already know this, so my question is are there any good tires for the aerostar or have many of you upgraded to 15 inch wheels and whatever wheels? Thanks...
__________________
1997 Aerostar Extended 3.0 2WD, 28K miles
if you plan on keeping it, get 5 7"x15"x114.5mm 5 bolt Ford rims off Ranger/Explorer etc at your local junke auto parts emporium or new if cash is no object.
then go with 225/70/15 radial tires
the 15" rim will fit under the EXT as spare. and 15" are far easier to find on a trip in the outback traveling
toss the skiny spare, it's rotted and a road kill waiting to happen
Thanks everyone, I was thinking about the 70 series tires but would like to keep my speedo as accurate as possible. The 15" rim sounds like the best option, I'll probably use that calculator to find a 15" tire that's the same height as the original. Thanks again...
__________________
Back in '86 14" tires were the norm on most vehicles, and sense there were only minor changes to the Aero throughout those years, including the rims.
Like what has been mentioned, if you are on a tight budget, I would recomend going with to the junk yard and picking up a set of Ranger/Explorer/Bronco II rims and putting new rubber on those. I picked up a set of Explorer Slicer Rim's and put 215/65-R15's on and love them. Gives the Aero a Trucklike look and only cost me $160 bones for the rims.
What size mazda pickup route? and year if you know...
90s-present B2000 (I think that is what it is called.) The one that is the same size as the Ranger, um, yea, well, it is a Ranger with different body clading. The door jam says built by FMC for Mazda, and almost everything in it is transplanted from the Ranger, except for decor.
__________________ '96 Ford Contour 2.0 I4 MTX 77k mi- Rear Ended 12/22/07 '97 Ford Aerostar AWD 4.0L v6 AT 81kmi '97 Chevy Lumina 3.1 v6 ATX 135k mi Parents old beater, temp vehicle
