Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Aerostar
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 03-30-2008, 09:52 PM
The Spruce Goose is starting off with a positive reputation.
Quote:
Originally Posted by 93nighthawk
EDIT: And you can also choose from Mustang/Crown Vic/Grand Marque/Towncar and also Jeep Cherokee/G Cherokee. All have the same bolt patern.
Crown vic rims on an areostar, i like.
  #32 (permalink)
Old 03-31-2008, 12:15 AM
copper_90680's Avatar
copper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to beholdcopper_90680 is a splendid one to behold
Quote:
Yes, Yoda
__________________
Tung
'93 3.0L Aerostar 2WD
'95 4.0L Aerostar AWD
'93 3.8L Taurus
Please check out our guideline
http://www.ford-trucks.com/guidelines.html
Wife? What wife? Oh, The Supreme Commander!
  #33 (permalink)
Old 05-15-2008, 12:13 AM
theconstantevolution is starting off with a positive reputation.
will 225 wide tires fit an aero? i got a brand new set on my van, but when they wear out i wanna get some 16" rims. i'm lookin at 225/55-16 for replacements in the same diamter. the stockers fill the wheelhouse well enough, but i want wider tread and smaller sidewall. 225/55-16 is only .2" smaller than the 215/70-14's and obviously 10mm wider.
  #34 (permalink)
Old 05-15-2008, 12:29 AM
xlt4wd90 is starting off with a positive reputation.
In theory, those measurements would indicate the bigger tire should fit. But in practice, the lower profile tires are usually more square than the higher profile tires. That's one way they have more tread on the ground. It's the corners of the more square profile that stick further out than the rounder profiles, and will be the parts that interfere, if they are going to. So there is a greater chance of interference with the lower profile tires that otherwise have similar ODs and widths.
My calculations show that a 225/60/16 size should be just about the same OD as stock, and will probably fit without interference because of its more rounded profile.
  #35 (permalink)
Old 05-15-2008, 12:39 AM
i used the miata net calc for it (i'm on a laptop with no side numbers for calc...it sucks) thats where i got the numbers from. i know its the same od, just dont know how much space there is on the back size for wider tires. notably, the fronts would be the problem for rubbing. thats why i asked.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
