Why does my pump gas truck sound like a diesel?
Old 01-13-2003, 11:59 AM
kman2785's Avatar
kman2785
kman2785 is offline
Hey,
My name is Kelly and recently I put the performer camshaft and intake manifold from edlebrock on my 1986 5.8L 351W HO engine.
I broke it in and changed the oil a few times. I floored it and going about 50 miles an hour it sounds like I have a diesel. The funny thing is before I broke it in the transmission line broke and I lost 4 quarts of transmission fluid and counting. Could my problem be transmission related?
Sorry that I can't describe the sound that I hear any better, but I need help and want to know if anyone knows what this could be!?
Thanks,
Kelly :-X23
Old 01-13-2003, 08:09 PM
78ford100's Avatar
78ford100
78ford100 is offline
Are you sure its in your engine? I'm no expert, but the first thing I would check is the timing. You had the distributor out when you put the cam in, so maybe its off, and you are getting spark knock when your advance moves. Just my $.02. Good luck,
78ford100
Old 01-13-2003, 08:12 PM
Ratsmoker's Avatar
Ratsmoker
Ratsmoker is offline
He is right. You are to advanced on your timing. Back it off a few. (Turn the distributor counter clockwise). Set the initial to 10BTDC or whatever it says to under the hood. Make sure the vaccum advance is disconnected.
Old 01-14-2003, 03:26 PM
kman2785's Avatar
kman2785
kman2785 is offline
Hey,
Thanks for your guy's input!
I know about the timing and such, I set it a t 10 degrees with the vaccume tube at the distributor removed. It also tells me to disconnect a wire that goes to my dura spark igniton but, I have that linked in with my MSD ignition and if I un hook it than it will shut my engine off. (no spark)
Is it critical to un hook that wire to get the timing right? Right now it says it's at 10 degrees.
I still get that sound... it starts at aroung 50 miles per hour!
Thanks
Kelly
Old 01-14-2003, 03:37 PM
Ratsmoker's Avatar
Ratsmoker
See where your timing is at around 3,000 rpm. It should be around 34 - 40.
Old 01-14-2003, 03:40 PM
Ratsmoker's Avatar
Ratsmoker
dpilot83
15
01-16-2014 02:09 PM
idfergusson
28
02-15-2007 09:11 PM
fatherdoug
09-20-2004 01:22 AM
idfliers
07-16-2002 07:30 AM
rescueranger
1983 - 2012 Ranger & B-Series
06-06-2002 10:50 PM
Quick Reply: Why does my pump gas truck sound like a diesel?
