Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-20-2008, 06:23 PM
07EXPYEL 07EXPYEL is offline
Garage is empty, add now
07EXPYEL is starting off with a positive reputation.
My towing report + Engine & Transmission Temperature Readings
I just finished a 800 mile round trip to from to San Diegolace. Much of the highway is flat, but there is a pretty good mountain climb about 80 miles outside of San Diego where you climb from <1000 ft to 4200 ft on a pretty steep grade.
My trailer is a 2005 31’ Trail Cruiser model 30QBSS ultra light travel trailer. I weighed the truck & trailer in Yuma AZ at a CAT Scale: Steer Axle #3600 , Drive Axle #4150, Trailer #5220 & Gross Weight #12,920.
Using my MSD Dashawk, I logged these peak temperatures:
Engine Coolant 216°F
Transmission Fluid 208°F
Cylinder Head 232°F
Peak temperatures were brief and quickly returned down. Normal tranny temps were about 185°F.
Speed easily maintained at 55mph uphill with RPM’s running between 2600 and 3500 RPM. I’ll try to post the data logs later.
  #2 (permalink)
Old 03-20-2008, 07:16 PM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
Thanks for the info.
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
  #3 (permalink)
Old 03-20-2008, 09:24 PM
2kcrewcab 2kcrewcab is offline
2kcrewcab is starting off with a positive reputation.
Do you also have datalog of your normal operation temp without towing? Thanks
Also, I've been looking at the dashhawk. how do you like it? Anything you don't like about it? Where did you buy yours?
  #4 (permalink)
Old 03-21-2008, 12:13 AM
Quote:
No normal data logs but I did observe Engine Temps of 197°F, Head Temps of about 200-210°F, and TFT about 185°F. Ambient temp 50-75°F, no towing & driver only.
So far I like it and the MSD fourm for the dashhawk seems to have a pretty good moderator (programmer guy) that responds to beta tester inputs. I found it online for about $300 shipped, then I called a local dealer in AZ and asked if they could match the $300 including tax and they did. I didn't have to wait and satisfied my instant gratification while supporting local. I quickly downloaded the beta 14 software and upgrade without any problems. I reported one bug and they already fixed it.
Note to my first message (I can't edit it now) My tow was between Phoenix & San Diego. Towing MPG average of 9.9MPG and the ambient temperature for the towing peaks were about 75°F.
I'm using the Reese Dual Cam Weight Distribution Hitch and sway control sysem. I weighed my trailer tounge to be about #450 when I started the trip with an extra #300 of water. The water tank is close the trailer rear axle so my tounge weight was a bit lighter at first. I didn't weight the tounge before I unloaded to know what the true weight was after weighing the rig. I think my tounge weight is only about 9% with >10% preferred.
  #5 (permalink)
Old 03-21-2008, 06:18 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Here's a plot of a 2 hour portion of my towing our 5000 pound camper over the Alleghanies last spring. PA Turnpike. Engine coolant never got above 200° that I can see. Longest grade was Sidling Hill, though, not a 4000' pass.
Click the image to open in full size.
Does the Dash Hawk indicate torque converter lock? I notice a higher transmission temperature when the transmission has to shift frequently, such as commuter traffic, than at steady cruising speeds.
3500 rpm has gotta be 3d gear.
-- Chuck
  #6 (permalink)
Old 03-21-2008, 10:12 AM
Quote:
3500 rpm has gotta be 3d gear. -- Chuck
No, the Dashhawk does not indicate torque converter lock. I'm going to request that feature along with the EOT (if available), commanded gear, and transmission slip. It didn't run much at 3500 RPM, most of the time it was 2600. Flat ground it will usually pull 55MPH in 6th gear, with a bit more hunting between 6-5 around 65MPH depending on the wind and grade. It would have been nice if they put a tow haul button to reduce the shifting. I would often turn the O/D off going up hill to lock in 4th or while going downhill to keep the speed in check.
  #7 (permalink)
Old 03-21-2008, 10:18 AM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
2007 Ford F-250
My Garage
MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.
Is the datahawk simply a datalogger? The tranny temp looks a little on the high side for the peak considering the ambient temp. You might want to consider a larger cooler as well as a tuner to firm up the shifts which should lower the temp as well.
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR GEn2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, Tenney 270A alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, MM suspension parts, etc Novi2k waiting on the shelf
Hope & A Prayer Motorsports
  #8 (permalink)
Old 03-21-2008, 10:28 AM
Dashhawk is a monitor and datalogger only so it can't control the transmission shifting. I was pushing the Expy pretty hard, 13K uphill at 55MPH. The peak transmission temps were only for a couple of minutes and were normally under 200°F. Next time I tow I'll probably log intake temperature (for the ambient temp) and or engine load. I'm can record a maximum of 5 paramters on 5 seprate files for about 20 minutes each log. I live in AZ so towing in 110°F heat isn't unheard of, but usually those extreme temps drop off pretty quick as the altitude increases. Good thing about knowing the tranny temps is when to slow down.
BTW, I have the largest cooler available from the factory and its really large.
  #9 (permalink)
Old 03-21-2008, 10:46 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Great info!
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #10 (permalink)
Old 03-21-2008, 04:23 PM
nfntruth nfntruth is offline
1993 Isuzu Trooper
My Garage
nfntruth is starting off with a positive reputation.
I leave on 3APR for my trip from San Diego to Charleston, SC. I use a scangage and can monitor similar data points, but unfortunately cannot log them. I will watch peaks and compare mine to yours. I am pulling a flatbed trailer with my Nissan, trailer weighs about 1900lbs, car around 2900 and I will probably add another 500 in cargo. I weighed the truck alone the other day, 5890, no driver. So my load will be similar. What kind of gas mileage did you get? I am hoping 12 at 65mph. The big tires and lift will hurt a bit, but overall I expect no problems. Towing it around town, didn't even notice except for stopping, even with trailer brakes, thats a lot of weight to stop. It wasn't a problem, just gotta keep it in mind.
__________________
06 F250, Lariat 6.0L Powerstroke, Draw tite hide a hitch gooseneck
2001 Isuzu Vehicross, Aussie Locker, 34" Kevlar tires, tons of extras, 1 of about 4000 ever made
1993 Trooper RS, Aussie Locker, 33" Mudders, 1 of 1500 in the US
http://www.fuelly.com/sig-us/55407.png
  #11 (permalink)
Old 03-21-2008, 04:45 PM
nfntruth, nice rig! I was checking out your pics. Looks like you might want to invest ina drop hitch if the trailer is hooked to the truck in those pics. Tugboating the trailer like that will be like pulling a parachute.
I have an 03 with the truxxx lift and 33's. I'm very pleased! I hauled about the same weight as you from Oklahoma city to Erie PA last spring and averaged around 13mpg. I ran premium gas the whole way.
  #12 (permalink)
Old 03-21-2008, 04:56 PM
nfntruth, you'll be about #1700 lighter then me, and with perhaps less wind drag. I averaged 9.9 MPG Round trip. It really made a difference if I ran 55 or 65MPH.
I don't know if premium will give you better MPG or not. Premium gas is still only about $0.20 higher then regular, or roughly +6%. If you get +6% better milage, then it might be better. When gas was only $2.00, premimum was +10%. You'll have enough fill ups you could try reg, mid, or premium and compare the MPG for the rest of us!
  #13 (permalink)
Old 03-21-2008, 05:40 PM
Ya, i wouldn't say that the premium gave me betetr mpg. i think it did, but since i didn't do the same trip with both, there's not telling. However, i did notice the engine ran much smoother than with regular. It seemed more powerful and responsive. but that could be seat of the pants talking! haha My reasoning for using premium was mostly thinking about the load I was putting on the engine. Why not? If it takes a little strain of your motor and maybe saves you 1mpg, i think it's money well spent.
For basic comparison, a 25 gal tank of reg at $3 costs $75. A 25 gal tank of premium at $3.20 costs $80. I'll sacrifice $5 to run smoother.
What I'd be interested in seeing is those of you with dataloggers. Try running both and see if there are any differences in temps. i know in my situation, the engine sounded audibly smoother and had much better throttle response. It'd be interesting to see if my $5 is as good as I think!
  #14 (permalink)
Old 03-21-2008, 07:52 PM
rich93cw rich93cw is offline
rich93cw is starting off with a positive reputation.
Quote:
Originally Posted by 07EXPYEL
I just finished a .........peak temperatures:
Cylinder Head 232°F
Peak temperatures were brief and quickly returned down. Normal tranny temps were about 185°F.........
These are really great data. Sound like Ford has a winning tow vehicle and so do we! Thanks for the info. Those temperatures are nice and low compared to what I had been getting in my '93 Club wagon (5.0L wHD Tow) with my 26' travel trailer (5000#) in the hills of West Virginia. All I can say about that is its good that I had Mobil 1 engine, trans, and axle oil!
  #15 (permalink)
Old 03-22-2008, 01:15 AM
Other then the HD tow package with 3.73 gears, I'm stock except for the K&N drop in filter and Mobil 1 synthetic motor oil.
Tags
2000, 26sk, 30qbss, 6r80, cooler, ford, normal, oiltemp, startcraft, temperature, tounge, towing, transmission, truck, trucks, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
