"Light Duty" F250 Rear axle seal replacement - Ford Truck Enthusiasts Forums
Old 03-20-2008, 06:52 PM
Halfbad Halfbad is offline
Halfbad is starting off with a positive reputation.
Hello everyone, I am new to this forum and have a question about my daughter's truck. It's a 1982 F250 with the 4.9L 6 and a semi-floating rear axle. We need to replace the axle seals as they are leaking a bit and the brake shoes have some gear oil on them. I am having a problem figuring out how the axles come out of the axle tubes. We have removed all of the parts from the backing plates and even removed the wheel cylinder as they will be replaced as well. But I can't see how the hub/axle/bearing assembly comes out. It seems to have a cup over the seal and I assume the outer bearing. Does the axle have to be released from inside the differential or am I missing something? This is unlike any other semi-floating axle I have ever seen before-not that I have a huge amount of experience, but I have changed a few seals before. And just to be sure, this is not the full-floating axle, it is in fact the eight bolt hub with semi-floaters. Thanks for your help.
Old 03-20-2008, 09:12 PM
Ranger GT2's Avatar
Ranger GT2 Ranger GT2 is offline
Ranger GT2 is starting off with a positive reputation.
I have a manual for 82 trucks that describes how to do this. I'll PM you and send me your email address and I'll send you the info.
Forgot your not allowed to pm yet.
Send me a message to steve-debbie-beck@sbcglobal.net
Old 03-20-2008, 09:20 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
If you have 4 bolts that hold a cover plate on in the center of the backing plate, those usually hold the axle in place. After you take the 4 bolts out, you have to get a slide hammer and pull the axle out.
If you don't have a 4 bolt retainer, you may indeed have an axle that has c clips on the inner part of the axle, and you have to take the cover plate off the rearend to get these out.
If you do not have a slide hammer, a quick and dirty way to get the axle out is put the brake drum back on the studs backwards. Put 3 lugs nuts on till they are even with the tip of the studs, and then grab the drum and slam it back against the lug nuts. This is a poor man's axle puller, and will work unless the axle is really stuck.
P.S. Here's a link with some info, if you know what type rearend you have.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 03-21-2008, 10:44 AM
Ranger GT2's Avatar
Sent you a reply to the message you sent me. Hope this is what you need and it helps
Rear Differential/Axle Identification LvBohemian 1987 - 1996 F150 & Larger F-Series Trucks 1 10-29-2014 11:51 AM
Semi-Floating Front Axle? radar_ridr 1999 to 2016 Super Duty 5 09-02-2014 10:18 PM
Question about f250 rear axle play meck1 1987 - 1996 F150 & Larger F-Series Trucks 5 08-28-2014 03:42 PM
what kind of rear axle do i have ? joey2fords 1987 - 1996 F150 & Larger F-Series Trucks 13 12-08-2013 02:06 PM
rear axle semi floating or full floating? FordOwnerJoey Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 11-06-2013 03:30 PM
Tags
82, f250, ford, rear, replacement, replacment, seal, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
