Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-19-2008, 10:24 PM
duggy is starting off with a positive reputation.
Unhappy Gas smell in car
I have a 2002 Escape, V6 3.0 Auto. The engine light came on a while ago, and at the advise of the mechanic (I trust him, BTW), I changed the EGR valve. Having done some research AFTERWARDS, this forum said it was likely the DFPE. Anyways, after the EGR was changed, the light came back on. So, I changed the DFPE. 2 days later, the light is on again, and now I smell gas, and it starts hard on cold, and idles a little rough. Mechanic (who I still trust, BTW) says sometimes the codes are misleading, and that it APPEARS to be the catalytic converter. Now, I ask you, am I too trusting?
Any OTHER guesses on what it might be?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-20-2008, 08:58 AM
sfcwoodret is starting off with a positive reputation.
There shouldn't be any issue with the cat. converter yet on a 2002 model. It sounds like a fuel/air mixture problem.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #3 (permalink)
Old 03-20-2008, 11:12 AM
DoctorCAD is starting off with a positive reputation.
If you had misfiring and rough running, you could have plugged a CAT, I see that it is all too common, based on this and other Escape forums.
P.S. It's expensive unless you are under the 80000 mile federal emissions warranty.
  #4 (permalink)
Old 03-20-2008, 02:28 PM
tcesni is new and has a neutral reputation at this point.
How many miles are on your Escape? If it smells like gas in the car, I wonder if the vapor management system might be involved. I recently replaced the evap. fuel management valve and the DPFE sensor on my '02 (didn't have a gas smell, though). Normally, a plugged cat doesn't show up at idle unless it is in really really bad shape. Bad cats usually let themselves be known by poor fuel mileage and sluggish acceleration. These things can be tough to pin down.
  #5 (permalink)
Old 03-20-2008, 02:50 PM
It does not run rough (at least not too often) or misfires. It has 108,000KM's (yes I'm Canadian) and isn't under warrenty anymore. There is an extended warrenty, but it doesn't seem to cover fuel issues. The smell is only when you are idling. As for fuel mileage, it seems to be getting close to what it is rated for and it doesn't seem to have sluggish acceleration, as most of the time I get whiplash trying to slowly accelerate and it does not like to do that. I will look into the vapor management system and see what that is all about. Thanks for the advise so far.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
