Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #31 (permalink)
Old 03-31-2008, 09:40 PM
aortizexcursion's Avatar
aortizexcursion aortizexcursion is offline
aortizexcursion is gaining momentum as a positive member of FTE. aortizexcursion is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by RACERX7775 View Post
HUH???? humm, lets redesign something because its doing too good of a job.... i guess ford thought that they could save $1 and give us all something that will scratch our trucks instead of doing the job it was designed to do.
Yes, thats exactly what I said. "Oversealing", WTF do they mean!!!
  #32 (permalink)
Old 03-31-2008, 09:45 PM
rolfe04655 rolfe04655 is offline
rolfe04655 is starting off with a positive reputation.
Didn't make any sense to me either.
  #33 (permalink)
Old 03-31-2008, 09:46 PM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is gaining momentum as a positive member of FTE.
and no one can figure out why ford is losing money...lol. side note what about the deal that they sold jag and land rover to TATA motors for like 1.7 billion.... and bought it back in 98 for like 6.? billion...
__________________
01 EXCURSION LIMITED, 4X4, V10, 325/50/22 TOYO'S ON CUSTOM POWDERCOATED WHEELS, 07 SUPER DUTY FRONT END, LOTS OF CHROME, 6 TV'S, CUSTOM STEREO, DUAL 175 AMP ALTERNATORS AND DUAL BATTERIES, CERVINI 3" COWL INDUCTION HOOD, CUSTOM MADE HID PROJECTOR HEADLIGHTS, TO MUCH OTHER STUFF TO LIST
  #34 (permalink)
Old 03-31-2008, 09:54 PM
tykateexcursion tykateexcursion is offline
tykateexcursion is starting off with a positive reputation.
it not a pain in the a** just take a six pack out and take your time. that is what i did and it worked. Hey if it works let me know
john
  #35 (permalink)
Old 04-02-2008, 07:18 AM
bcrewcaptain bcrewcaptain is online now
bcrewcaptain is starting off with a positive reputation.
same thing they did on my taurus wagon, it would trap leaves, pine needles etc, between the gasket and the drip channel causing it to kill the paint/become a rust have....maybe they actually just learned from mistakes?
  #36 (permalink)
Old 04-03-2008, 12:30 PM
tykateecursion,
I assume when you take that interior trim off you just have to take off the bottom piece of the trim, the one with the handle in the middle of it. Do you just easily pry the trim off or is there any trick to doing it?
thanks
Jon
  #37 (permalink)
Old 04-03-2008, 09:13 PM
wallz's Avatar
wallz wallz is offline
2002 Ford Excursion
wallz has a good reputation on FTE. wallz has a good reputation on FTE.
Quote:
Originally Posted by rolfe04655 View Post
tykateecursion,
thanks
Jon
Yes,
Once you take out the screws from the handle, the trim pulls straight away from the glass, (not up) only the clips holding it on after screws out. Had mine apart to lube lock mechanism so it locks properly. The lock did actuate and you could hear it working but the glass didn't lock down. You might as well lube it up while you have the door apart. (I just used silicone spray.)
  #38 (permalink)
Old 04-03-2008, 11:07 PM
yes you just pry it off but take your time at that point get another six pack, you probally need to remove all pieces of the trim, did yuou find any loose bolts??? or just loosen the boldt and readjust the plastic trim???
  #39 (permalink)
Old 04-05-2008, 07:18 PM
I haven't had a chance to do it yet. So there are some bolts in there that can be loosed up to move the rear piece of plastic up that surrounds the outside rear hatch handle?
  #40 (permalink)
Old 04-05-2008, 10:22 PM
yup, i would loosen all the nuts to just snug and the move the plastic trim up ward on the side that is rubbing on the barn door (after looking at mine the plastic is covered by the edge of the gasket) then tighten the bolts snug be careful not to overtighten as this could snap the screws off the plastic piece. close the barn doors and slowly lower the upper hatch. check for clearence and keep adjusting till you find that the plastic is not rubbing on the barn door. once you have a good clearence. snug the nuts up and put all the plastic trim on the inside back on. be carefull and make sure to take your time as the plastic peg will snap off if you rush.
  #41 (permalink)
Old 10-26-2009, 07:06 PM
scoutdad scoutdad is offline
scoutdad is starting off with a positive reputation.
Hello!
I saw your note abour your excursion having a rubber strip all the way across the liftgate.
My had that, but was ripped and I took it off.
What year is your excursion? I can't seem to find that part any longer at ford.
Tags
1c7z7842084aa , excursion , ford , hatch , rear , weatherstrip
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
