Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-19-2008, 02:56 PM
kart6fast is starting off with a positive reputation.
P0171,P0174 Freeze frame data
Have been searching for the fix for these codes for a while.Done all the
standard fixes suggested on this site.Borrowed a scanner and was able to get
the following freeze frame data .Does this point to a paticular problem?
Fuel sys1 CL,using Ho2s
Fuel sys2 n/a
calc load % 74.9
coolant 194
St ftrm1 -2.3
Lt ftrm1 5.4
St ftrm2 -3.9
Lt ftrm2 3.8
Engine rpm 1068
mph 4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-19-2008, 07:26 PM
flagbagger is starting off with a positive reputation.
Po171, Po174
I have no experience with freeze frame data, but FYI, my 97 (4.2) was setting PO171( system adaptive fuel too lean - bank 1), PO174 (system adaptive fuel too lean, bank 2) and PO305 (misfire cyl 5) which I thought might be IMRCs at the back of the lower intake manifold at first...but listening to the advice here at FTE saying it is normally indicative of a vacuum leak, I tracked down two leaks by applying vacuum to all the small vacuum lines in the engine compartment - the brake vacuum nipple was holed/broken and a small vacuum line behind the battery tray (red line (EVAP?) plastic hose joiner at elbow was cracked). I couldn't believe that small amount of loss vacuum could set 3 codes continuously but it did (engine was indicating 19 inches of vacuum throughout the problem. (Fixing the vacuum leaks made all the codes go away - fingers crossed they stay away).
Previously, I had checked my Electronic Vacuum Regulator & it was within specs, & I had changed my differential pressure feedback sensor (DPFE). I checked both Intake Manifold Runner Control ( IMRC) while I had the lower intake manifold off and cleaned the EGR passages as well . Rubber elbow at at RH end of plenum was also replaced as well as new hose around PCV valve area.
To eliminate #5 spark plug as a problem, I switched it with #6 to see if the problem moved.
Hope this helps
Flags
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
