Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 03-19-2008, 02:12 PM
STGFordCrazy04's Avatar
STGFordCrazy04 STGFordCrazy04 is offline
STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold STGFordCrazy04 is a splendid one to behold
STGs D60 tech thread Part 3- useful diagrams and a trick
Exploded view of a D60 Front.
King pin view
When I got everything in my front 60 set up I had a wobble between 35-50mph. Since everything was new I knew it had to be an installation problem. I checked all the bearings and kingpin. I regreased and retightened everything. I drank and banged my head on it out but couldnt fix it. Through the vast knowledge of a former member I came up with the fix. Try to follow because Im not sure Im explaining it correctly...The extra weight and diameter of my 38.5" swampers is too much for the factory kingpin spring to handle which lessens the springs force on the bearing. This will simulate a worn out kingpin or ball joint. To fix this I used 7/8 grade 8 flat washers to add more preload on the kingpin. Works like a charm!
heres a pic
__________________
Kris
Please do not PM me. My email is STGCountryboy312 at AOL dot COM
Quote:
Originally Posted by thorseshoeing
Yes you are the anti christ...
  #2 (permalink)
Old 03-19-2008, 02:34 PM
crappy push pull steering diagram for D44HD and D60s in 77.5-79 F250s
__________________
Kris
  #3 (permalink)
Old 03-20-2008, 03:25 AM
dirtyoffroad dirtyoffroad is offline
dirtyoffroad is starting off with a positive reputation.
How many washers?it looks like 3 in the photo.I need to rebuild both sides of mine
  #4 (permalink)
Old 03-20-2008, 04:31 AM
fdude64 fdude64 is offline
1979 Ford F-250
fdude64 is starting off with a positive reputation.
ok thanks it is clear to me now.
__________________
the difference between the men and the boys is the size of their toys
http://www.youtube.com/watch?v=xR273bcYSzQ
  #5 (permalink)
Old 03-20-2008, 06:46 PM
Another diagram from Mr N.
__________________
Kris
  #6 (permalink)
Old 03-22-2008, 08:40 PM
Here is a good Locking hub diagram
__________________
Kris
  #7 (permalink)
Old 03-25-2008, 01:04 PM
Ronin4x4 Ronin4x4 is offline
Ronin4x4 is gaining momentum as a positive member of FTE. Ronin4x4 is gaining momentum as a positive member of FTE.
Quote:
1. How many washers did you use until the problem was corrected?
2. Did the "former member" with the vast knowledge have punisher skulls on his trucks door?
3. How many miles have you put on since this fix and is the DW still gone?
Thanks.
__________________
Ford-man Forever!
  #8 (permalink)
Old 03-25-2008, 02:15 PM
1-I used 2 on the driver side with the king pin cup and 3 on the passenger side with the steering arm. I noticed the steering arm with the machined in steering cap was a few thousandths deeper than the stock one.
2- Yep thats him.
3-probably 300 miles or so. I dont keep up with it. Death wobble is gone up to 70mph. I havent driven it faster than that since.
__________________
Kris
  #9 (permalink)
Old 03-26-2008, 01:33 PM
Good to hear that worked, and is still working. Yes I thought you were talking about Pro. I remember a thread from several years back when fishman was having a death wobble problem and Pro described this cure. I'm not running a D60 yet but I'll keep this in mind. Thanks for the good tech!
__________________
Ford-man Forever!
  #10 (permalink)
Old 03-31-2008, 12:40 PM
krol's Avatar
krol krol is offline
krol is starting off with a positive reputation.
I really appreciate the pictures in this thread. I've had the same problem since I threw the D60 under my truck but until now didn't quite understand the fix. Thanks. I have just one question about the size of the washers. I went to pick up some 7/8" washers but they looked huge! Is it 7/8" outside diameter of the washers or is it the washers with a 7/8" inside diameter opening? I haven't had time to go out and measure the king pins and my truck is being driven by the g/f today, sometimes I think she loves my truck more than I do. Thanks for the help.
__________________
1992 F250 460 5 speed
  #11 (permalink)
Old 03-31-2008, 12:45 PM
The washers are 7/8 ID and maybe as big as 1 3/4 OD. They are the normal 7/8" washers you would buy for a 7/8" bolt. Yes they are big.
Admin puts the scales in the top right hand corner for a reason. If you use this trick how about click on it for me.
__________________
Kris
  #12 (permalink)
Old 03-31-2008, 02:01 PM
krol's Avatar
STGFord consider your rep added to. Thanks for the help.
__________________
  #13 (permalink)
Old 03-31-2008, 02:03 PM
75F350's Avatar
75F350 75F350 is online now
1973 Ford F-100
My Garage
75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE. 75F350 has a great reputation on FTE.
Not being ctitical, but when I performed this modification, I had read on another site that the 7/8" washer was the correct size, and I had to make it smaller to fit.
The more crtitical measurement is the OD, and not the ID. Many manufacturers may have different OD dimensions, and still have the same ID.
These examples and pics are Dorman, and Hillman fasteners. I even included a pic with a tape measure and stock spring shim for reference.
Image of spacers for king pin pre-load - Photobucket - Video and Image Hosting
  #14 (permalink)
Old 04-01-2008, 05:34 PM
krol's Avatar
So last night I tore into the King pin caps. I ended up using one washer on each side. I first put in two washers on each side but it seemed like the steering was binding and didn't feel right, then I took one washer out on each side and she rides like a dream. It took away all signs of DW.
__________________
  #15 (permalink)
Old 04-01-2008, 05:42 PM
Boom shacka lacka!
__________________
Kris
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
