This is how i release the carbon outta my V-10
http://good-times.webshots.com/album...aXXXd?start=48
Video 510 is what i am refering to towards the title of the thread youll see at the end of hte vid. My buddies call it "first time". BTW turn the volume *** up all the way on the webshots video player because for some reason it is set in the middle.
Enjoy the vids and let my kno what you think.
Originally Posted by rg200amp
if only it was that easy to clean carbon, i would have a new engine by now!!!!
add some sea foam to the vacum line, cut the engine for 10 min. then do that.
THAT WILL BE CARBON CLEANING
Originally Posted by i eat hybrids
http://good-times.webshots.com/album/562291170qaXXXd?start=48
That would drive me nuts.
Originally Posted by nebmike
Matt, Matt... Matt! You GOTTA get that steering wheel fixed! How can you stand to drive down the road with your wheel jacked like that?!?
Originally Posted by Monsta
sooooooooooooooft shifts. Get a valve body, a shift valve, new springs or at least a tuner.
You should hear it at 5500rpm!
Me and my buddies always do "first time" thats why i am surprised that i havent had any probs besides (crank snser) with this engine. Hell, she only uses bearly half a quart every 3k. My one buddy loves it and he does it in his 07 150 4.6 lol. But as u could see in one of the vids that the shifter wouldnt go into first. Well, she doesnt go into first manaully anymore. So i have to get the shifter fixed. When i fix the shifter, im gonna try and make it strong because i cant resist "first time". Its way to addicting, especially if ur engine loves to rev since the top end is SOHC.
Also, i dont even want to kno what "first time" would be like if i had a transfer case in four low. Mines 2wd and it still throws my head in the seat. One time i did it and my buddy was behind me and said he tought my front end had hydraulics lol. Can we say v-10s are torque monsters? lol
I just put it in drive and go. I can hit 5400rpm in first depending on load and can do 80mph in 2nd in drive. I've found if you shift manually it shifts super slow and sloppy even with my tuner. I don't beat my truck but every once and a while I'll take off from a stop with it to the floor to help it clear its throat some. I'll run a tank with fuel injector cleaner every 15k and some water remover every 4-5 months but thats about it. I'm not a fan of using a lot of cleaners and solvents because over time they leave deposits. I used to run Marvels Mystery oil in every tank on my 74' F-100 until I went to change plugs and saw the insulators were dyed red.
Carbon Removal
BTW, genises, read this thread and mayb youll change your mind about floor'n the good ol v-10.
https://www.ford-trucks.com/forums/7...ing-style.html
U really dont save gas if u drive ur v-10 like a g-ma. When i always floor mine i notice a very small fuel usage increase. And i thought i was crazy for thinkin that until i read that thread.
