Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 6.4L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-18-2008, 11:39 PM
Hollywood2005 is starting off with a positive reputation.
DPF Delete with no programing
so what happens if I get rid of it, it goes into constant regen is what I hear...
and no one has found a way to trick it to turn off yet??....
Has anyone figured out what causes it?? Back pressure, heat,..... something has to trigger it on and off???
I know there are guys out there that have it off; so what are they doing jsut letting it eat fuel?
there has to be a way
If we figure it out then we can just run a tuner with no DPF....... Good sound, tunable on the fly, bigger tires, better MPG and MORE power
__________________
2008 F-350 Lariat Black Crew cab Short box
Pro Comp Lift, 37" Toyo's on 20" Eagle Rims
MBRP 4" Dual Exhaust
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-19-2008, 09:08 AM
origcharger is gaining momentum as a positive member of FTE.
"Has anyone figured out what causes it?? Back pressure, heat,..... something has to trigger it on and off???"
Its been reported that if you take it off without a regen deleting program, its the drive cycle thing that triggers the regenerations and the lack of expected heat in the system from the regeneration that won't shut it off, that causes the grief.
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #3 (permalink)
Old 03-19-2008, 12:51 PM
SouthTexasDiesel is starting off with a positive reputation.
DPF backpressure is the parameter that the regeneration cycle mainly focuses on. But it reads other parameters such as the 4 EGT sensors (yes 4, 3 in the exhaust and one just after the exhaust manifold), boost pressure, rpm, engine temps, etc.
If someone just takes off the DPF they will experience the constant regen. This is basically a fail safe for the truck, so you don't blow out the DPF. If within a certain amount of time or miles the truck does not go through a regen the cycle will automatically kick on, and with the appropriate sensor readings it will never shut off.
__________________
08 F-350 Cowboy Edition 6.4 4x4 CC DRW 6-speed w/3.73 gears
Programmed with SCT LiveWire with DPF delete tune
Full 5" DPF & Cat delete pipe from Bay Area Diesel
6" Aussie stacks painted black
Random other goodies
  #4 (permalink)
Old 03-19-2008, 08:38 PM
so it sounds like its not just crossing a couple of wires....... eh!? LOL!
__________________
  #5 (permalink)
Old 03-19-2008, 10:41 PM
More like several hundred dollars on a programmer than just a couple wires.
__________________
  #6 (permalink)
Old 04-12-2008, 04:20 PM
straight-piped08 is starting off with a positive reputation.
i straight piped my 08, and every approx.1300 km it went into regen and i went to the dealer and kept getting dpf resets, the regen mode triggers when it reads to much back pressure, my dads truck has the dpf out but still has the muffler and it never has went into regen mode yet and he put on atleast 3000-4000km.
  #7 (permalink)
Old 04-12-2008, 05:22 PM
rollerstud98 is starting off with a positive reputation.
Quote:
If true, you're better off just sucking it up and buying the programmer to get the regen cycle eliminated, save some money in the long run.
  #8 (permalink)
Old 04-12-2008, 11:19 PM
SANDDEMON08's Avatar
FORD POWERSTROKE JUNKY
SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.
In addition, it looks a total milage since last regen, their is a parameter that will cause it to go into regen if no regens have taken place in X amount of miles.
__________________
Got beer ? 434HP 765 TQ
2008 F350 SD CC FX4 ON 20's, 6.4 PSD,TORQ-SHIFT,3.73 REARS, NAV, BLACK LEATHER SEATS,DASH DAQ GAUGES, AFE STAGE II INTAKE,CUSTOM TUNING, SEIC IDLE MOD,AMP REASEARCH STEPS, LINE-X SPRAY IN BED LINER, T-REX BILLET SIDE VENTS.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
