E40D Transmission - Ford Truck Enthusiasts Forums
E40D Transmission
Old 03-18-2008, 10:25 PM
sacheeze sacheeze is offline
sacheeze is starting off with a positive reputation.
E40D Transmission
anyone know anything about this tranny bought this truck tonite only to find it has no reverse (auction) bought it well worth the money,good int and engine (300) and runs like a bat outta hell all cept reverse. any tricks or am I buying another transmission for it? Anyone know where to find rebuilt info?
Old 03-18-2008, 10:47 PM
flareside_thunder flareside_thunder is offline
flareside_thunder is starting off with a positive reputation.
Good thing is the E4OD is a pretty stout tranny and there are upgrades you can get for it.....You could get it rebuilt but if you do get it done with hardened and heavier duty parts than OEM...or take it to a guy who has a habit of doin em for the Gen 1 Lightnings (Same tranny)Luck
JR
Old 03-18-2008, 11:23 PM
gweeds's Avatar
gweeds gweeds is offline
gweeds is gaining momentum as a positive member of FTE.
Do you know that its just completely shot in reverse? If not, replace the fluid/filter and clean out everything. This sometimes helps, and costs much less than a new/rebuilt tranny...
Alltho If you plan on doing any towing with it, its a pretty good idea to get it rebuilt and put on a beefier cooler setup.
Old 03-19-2008, 01:31 AM
Mtthwvn73's Avatar
Mtthwvn73 Mtthwvn73 is offline
Mtthwvn73 is starting off with a positive reputation.
I don't know a heck of alot about them, but all I've been hearing is that their really expensive to get rebuilt. I've heard upwards of 2K, but if your planning on keeping it i'd say it's worth it.
Matt
Old 03-19-2008, 09:18 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
could be fluid level or the elec. switch on side of trans. or shifter is out of alignment.
Old 03-19-2008, 12:24 PM
gweeds's Avatar
yeah, also, check that the shifter linkage (on the driver side of the tranny) is properly aligned. If you do a search for it, you can find out how to ensure proper alignment.
Old 03-19-2008, 12:27 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
The MLPS is the first thing I'd replace. It translates the lever position into an electronic signal to the tranny. If for some reason it's not telling the tranny to go into reverse, it won't go.
Old 03-19-2008, 12:55 PM
quicklook2's Avatar
mlps=manual lever position switch.
that was the elec. switch i was talking about.
Manual transmission question coloradotrk 1967 - 1972 F-100 & Larger F-Series Trucks 14 10-19-2014 02:38 PM
Reverse sensors Ryan50hrl 2004 - 2008 F150 9 01-29-2012 02:12 PM
94 F250 - No reverse lights! Pharticus 1987 - 1996 F150 & Larger F-Series Trucks 9 01-18-2012 06:42 PM
1969 F-100 Transmission work Nuggetfn22004 1967 - 1972 F-100 & Larger F-Series Trucks 4 07-21-2006 01:54 PM
A4LD Reverse slips, all drive gears ok ppanepinto Bronco II 5 04-11-2006 01:01 PM
Tags
e40d, ford, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
