Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-18-2008, 09:57 PM
expy37at expy37at is offline
Garage is empty, add now
expy37at is starting off with a positive reputation.
Gas tank capacity only 28 gallons, increase it somehow?
We're considering buying a 2008 Expy to replace our 2001 Expy with about 70,000 miles.
Both would be/are 4x4's.
We tow about 4500 pounds a lot, usually around 58 to 62 mph and have been getting about 10.5 mpg at lower altitudes and 11.5 out west at higher elevations.
When I went to the Ford dealer last week, I noticed on the sticker that the tank only holds 28 gallons instead of the 30 gallons for the 2001 Expy.
The smaller 28 gallon tank for the standard length is sort of a deal killer because to fit the Expy into the parking garage where we live at a condo, I need the standard length. The longer one is an accident waiting to happen possibility.
Has anyone else had this issue come up and how did you solve it? Is there an aftermarket tank of some sort to carry extra fuel?
  #2 (permalink)
Old 03-19-2008, 05:45 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Easy put a 5 gallon jerry can on the trailer tongue and boost fuel capacity to 33 gallons. Off road shops should have these cans and the rack to hold them.
I'm getting 12 - 14 towing our 5000 pound camper at 65mph. 6th gear at 1800 rpm. We commonly tow across the PA mountains several times a year. I'd think you'd get that as well at those lower speeds if you let the transmission do its job. I average about 19mpg over the same terrain without the trailer at ten-over.
I'd order the 3.73 axles based on our Explorer and Expedition towing experiences.
I strongly recommend the HD towing package (about $350 if factory fitted) as you get better engine and transmission cooling plus the complete wiring package. Yeah, the 6000 pound standard max towing capacity is sufficient for our 5000 pound trailer but the extra ton and a half cushion is at least confidence building and there's no fuel hit with it.
I mounted an OBS2 interface transmisson temperature gage. First tow with it won't be for a couple more months though, but knowing trans, coolant, cylinder head temperatures also takes the worry out of towing.
-- Chuck
  #3 (permalink)
Old 03-19-2008, 10:55 AM
n2umr n2umr is offline
n2umr is gaining momentum as a positive member of FTE.
Why should 2 gallons make a difference!?!?! I had a 99 with the 30 gallon tank and I would get about 315-325 a tank. With my 07 and the 28 gallon tank I consistently get 340-360 a tank, who cares about the other 2 gallons. Smaller tank more mileage, don't let 2 gallons change your mind.
Mark
Tags
1996, 2007, 28, 30, capacity, expedition, ford, fuel, gallon, gallons, gas, increase, size, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
