You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
So I have been doing some reading and want to start making BD from WVO. Tell me if I am headed in the right direction...
1. Collect WVO
2. Filter WVO to remove large chunks
3. Test Titration Levels of WVO
4. Heat WVO to 130F and turn off heat
5. Add Methoxide to Heated WVO slowly
6. Mix the mixture for about 2 hours(pump mix)
7. Let it sit
8. Drain off Glycerin from the bottom of tank
9. Wash Bio with water mister for about 24 hours
10. Let it sit and drain off water from bottom of tank
11. Run bio through drying tank with fan blowing as oil is sprayed into top of tank
12. Filter bio
13. Store bio
The questions I have are, what is the best catalyst to mix with Methanol to make the Methoxide and how do I know how much I am adding into the proccessing tank? Also, what are the times for each operation? ie: mixing, sitting, etc? Also, what else would you add? Thanks
Kyle
__________________
04 crew cab 6.0 4x4
train horns
SCT XCAL2 from Matt @ Spartan
remote start
5" lift with 35's
traction bars
4" MBRP turbo back straight piped to 6" single stack
some other pullin goodies
Answered my question about when Magnesol was added in the process. thanks!!! I will print this off, now to find a few people to go into this with me...
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
