I have a PIE adapter installed in my 2007 F250 to run my Satellite radio through, and Im wondering if there is a way to also connect my IPOD to do. I know I can press the aux button twice and it seems like two different modes.
Anyone have any insight into this? Or another way to connect my IPOD? Doesnt seem like FM transmitters work very well, especially in the city areas of FL
__________________
2007 F250 6.0 PSD CC Lariat
4.5" Donahoe Racing Lift Kit
DirtLogic Steering Stabilizer
20x10 KMC Diesel Wheels
35x12.5 Toyo MTs
4" Magnaflow SS Turbo-back exhaust
EDGE Juice Platinum w/ Attitude
In my 06 mustang I used a pair of rca splitters to connect two headphone to rca adapters. The two modes is just a wierd thing from when they cracked the firmware
Be careful using RCA splitters to connect two items to one RCA input. If both items are on at the same time it can damage the unit they are plugged into.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
For all of you following this thread, I contacted PIE and they were very helpful. They make a splitter that plugs into the single RCA input, and the box has two inputs on the other side of it. The part is SON-AUX. For my Ipod, they also sell a cable that goes from the bottom of the IPOD to the RCA input, and it also charges the IPOD. The switch works off the power of either device; so when my satellite radio is on, if I turn on the IPOD it will take over and vice-versa. PIE only sells directly to dealers, so they referred me to www.AncoAuto.com. They had the parts I needed, and "Andy" even called me shortly after I placed my order to confirm I was buying the right parts since it was an odd order. You dont often get customer service like I just experienced with both companies; highly recommend doing business with them both!
__________________
35x12.5 Toyo MTs
