Update on my '64 F250
Well it may not be much, the order was under $100.00 (around 80 I think) but I finally got it in the mail today. My first parts on a long list of items that need either replacement or repair. My Weather stripping has finally arrived. I will be installing it over the weekend, since I work shift work (look that song up and You'll know my hours) my weekend starts Tuesday afternoon when I finish work and ends Saturday Night at 11:00 pm. I can't wait, soon I will have new stripping and my doors should stop leaking at the seams.
Once you glue the strips on the door, use masking tape to secure it, especially at the corners. Close the door till it just touches the striker plate.
Remove the dome lamp bulb so your battery doesn't go dead.
The new weatherstrips will be fatter than the old flattened out originals, so the doors may have to be closed harder to latch them.
also make sure the ends of the w/strip on the doors is at the bottom as original and I would save the originals so you have an idea of how the rubber is supposed to lay...mainly around the cowl area where it transitions up the vent window area on the door...lotta curves and such...
- cs65
- cs65
78F150RangerXLT
03-22-2009 01:56 PM
Imdok
10-11-2007 01:11 PM
