can someone post pictures and links to where you got your custom shift knobs..i want to trick my interior out and the shift knob seems like somethin that would be simple and cheap to change out
The knob is threaded on. On the last floor shifter I had I "liberated" a tap handle from a local bar (Red hook ESB was the name of the beer). Then I drilled out the old threads and then cut new threads so the tap handle would screw onto the shifter.
__________________
'97 F-150 XLT S/C 8' bed Leer fiberglass shell
then all you need to do is make the hole in your new handle just slightly smaller than the shaft. Then put some towels on the ball and hammer it down tight. The handle on my reloading press is slip fit and I hammered it on, now I can lift my table by the handle, so it will hold on your transfer case. Should you want more, you can epoxy it too or if your really crafty you can use a release agent (cooking PAM oil works pretty on JB weld) on your splined shaft, build it out with an epoxy and thread your new epoxy adapter for the handle.
im in a machine shop class at school could i just run a die down the shaft to the end of the spines and then thread on my new shift knob,seems like it would be pretty simple
When I was in high school, I used time in shop class to drill out an 8 ball to make a shifter knob for my F-100. I just kind of twisted it onto the shifter and it self tapped, held up really good for several years. When I tried to put it in my new 95 F-150, the shifter was a little bigger and caused the 8 ball to split in half. Right now I have an aluminum shifter ball with LED's in it. It's a little ricey, but since the top half unscrews it makes for a real handy flashlight. I was amazed how bright 6 LEDs could be. If I turn it on at night, it blinds me in 2nd and 4th gear.
__________________
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
i go back to school monday been off on spring break all week,im gonna talk with the teacher and see what he thinks, i may just end up ordering a pistol grip shift knob for it and drill the threads out and cross dirill it and put some button head set screws in it
