2" or 2.5" Leveling Kit
03-17-2008, 07:41 PM
on
Looking at an Auto Spring Leveling Kit, but I am not sure which way to go:
2" With factory block
2.5" with add a leaf or new lift block
Major concern of 2.5" is the new axleshaft angle, is this a concern or not?
Thanks for your help and or pics.
03-17-2008, 07:49 PM
on
If you put 2" on front it will be level ... 21/2" the front will be higher than rear.
03-18-2008, 04:09 PM
on
"If you put 2" on front it will be level ... 21/2" the front will be higher than rear."
I have the 2.5" and it is NOT front higher than rear. As a matter of fact when measured I am still about .25" nose down on level ground. That is with a 100lb. dog box in the back as well.
03-18-2008, 04:33 PM
my 2.5" makes my truck exactly level
there is 0 concern with driveshaft angle
