White Smoke from Exhaust - Ford Truck Enthusiasts Forums
Old 03-17-2008, 02:26 PM
07 F250 Aggie Mobile's Avatar
07 F250 Aggie Mobile 07 F250 Aggie Mobile is offline
07 F250 Aggie Mobile is starting off with a positive reputation.
Any idea what could have been the cause of white smoke coming from my exhaust within muinutes of starting it one morning? 2006 Super Duty Thanks,
Old 03-17-2008, 02:43 PM
elmo8641 elmo8641 is offline
elmo8641 is starting off with a positive reputation.
what engine?
Old 03-17-2008, 02:55 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I think he's a 6.0L Power Stroke owner,in which case the white smoke may be a head gasket failure?
Old 03-17-2008, 02:58 PM
Corner Gas's Avatar
Corner Gas Corner Gas is offline
Corner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant futureCorner Gas has a brilliant future
Sounds like water getting into the combustion chamber
Old 03-17-2008, 03:21 PM
Uh-Oh
It's only happened once...and only lasted for about 10-15 minutes. Should I be headed back to the dealer??
Old 03-17-2008, 03:26 PM
capn kirk capn kirk is offline
capn kirk is gaining momentum as a positive member of FTE.
happened once if it was especially cold out then it could be your piston sleves and rings were expanding/contracting and some oil probably seeped into the cylinder
for gas motors general rule is white smoke oil in cylinder black too much gas.
if it happened once its probably nothing to worry about. if it happens again i would look for something wrong
Old 03-17-2008, 03:32 PM
redford's Avatar
Once isn't a big deal....twice, it's time for a visit to a dealership so they can lie to you.
Did I say that outloud?
Old 03-17-2008, 03:36 PM
you should post this in the 6.0l forum. prob get better help there.
Old 03-17-2008, 04:32 PM
something like white smoke can be so many things that a dealer, unless you got a good one, is goin to blow it off
Old 03-17-2008, 06:59 PM
ryaneverk2's Avatar
ryaneverk2 ryaneverk2 is offline
ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.ryaneverk2 has a great reputation on FTE.
Moved to the 6.0L PSD section (assuming this is a 6.0).
07 F250 Aggie Mobile, do me a favor and edit your signature to reflect what engine your truck has. It's nice to know the color but it doesn't help when folks are trying to diagnose an engine problem.
Is the 2006 Super Duty in question a different truck than the 07 in your sig?
Old 03-17-2008, 09:37 PM
toolman05kr toolman05kr is offline
toolman05kr is gaining momentum as a positive member of FTE.
If it keeps happening then chances are that the egr cooler has failed. good luck and keep us posted.
Old 03-17-2008, 09:54 PM
doubledee715's Avatar
doubledee715 doubledee715 is offline
doubledee715 is starting off with a positive reputation.
Quote:
Only??? 10mins is way too long for the truck to blow white smoke. If it was for 10-15secs then it could be normal. I don't think headgasket/bolt issues rear their head on cold starts....more while towing or while hot. ask them to pressure test the coolant system
Old 03-18-2008, 11:19 AM
electod electod is offline
electod is starting off with a positive reputation.
The EGR cooler on mine has gone out twice in the last year 2005 F250 in the last year it is in the shop right now for the second time the smoke starts out a little then it will come out until the engine warms up eventually it will go out completely then you will see blue smoke along with the white smoke I was told that once the EGR cooler goes the oil cooler will follow hope this helps
Old 03-18-2008, 11:58 AM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
If still under engine warranty. Go directly to dealer. Pay the $100 deductable and have no worries as to what it might be.
Old 03-18-2008, 12:06 PM
jmaskew's Avatar
jmaskew jmaskew is offline
jmaskew has a very good reputation on FTE.jmaskew has a very good reputation on FTE.jmaskew has a very good reputation on FTE.
Quote:
The oil cooler "can" become plugged due to the sand in the cooling system when the block was made which will cause the EGR cooler to get hot and fail (install a dieselsite coolant bypass filter - it's worth the money). I am assuming when your egr cooler failed the dealer didn't replace the oil cooler. I had to take my truck to another dealer in town to have it fixed right. If your truck is still at the dealer ask them to replace the oil cooler.
Intermittent heavy white smoke 04F250CC60 6.0L Power Stroke Diesel 11 08-23-2016 10:29 AM
White smoke from exhaust, no loss of coolant, oil, or anything else Leopold 1999 to 2016 Super Duty 34 12-02-2012 11:43 AM
White Smoke from Exhaust Robil7 6.4L Power Stroke Diesel 8 06-08-2011 10:06 AM
White smoke and black soot on exhaust... Heads or rings? BRay09 1987 - 1996 F150 & Larger F-Series Trucks 18 08-06-2010 03:48 PM
White smoke, and oil leaking from exhaust ztodd377 1999 - 2003 7.3L Power Stroke Diesel 61 05-18-2010 09:09 PM
Tags
2004, 60, ac, excursion, exhaust, f250, ford, hot, powerstroke, smoke, smokes, truck, tune, water, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
