Oil Filter Adapter
Old 03-17-2008, 12:22 PM
Chasjr1's Avatar
Chasjr1
Chasjr1 is offline
Oil Filter Adapter
I just joined this forum after buying a 1999 F150 4x4 Lariat 5.4l a few months ago.
Now I have a big problem, and hope someone can help.
The truck is having the engine replaced in a local shop. Somehow the oil filter adapter (Ford P/N F75Z-6B895-DA) got cracked. My truck has the remote oil filter without the oil cooler. The oil pressure sender screws into a boss on the remote hose. All the dealers show this part superseded with no replacement.
The dealers also show the adapter with the oil cooler (Ford P/N F75Z-6881-FA), and state that it is a direct cross. The only problem with that, is that oil pressure sender connects directly to the adapter, and is too close to the front differential. It would also require a new remote hose assembly to make it work.
Is there anybod here that have run into this problem, and if so, how did you fix it.
I live in Houston, but work in Louisiana. The truck is in a shop in Kenner, La.
Any Help would be appreciated.
Old 03-19-2008, 09:19 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Welcome to the forum.
My 01 has the filter on the adapter as well as the sending unit with no problems clearing the front differential. Maybe try one of those unless you have a remote filter and want to keep it.
Old 03-19-2008, 10:31 PM
Chasjr1's Avatar
Chasjr1
Chasjr1 is offline
Thanks for the reply. After going to the regional manager for the company replacing the engine, he states to me that they will replace with one similar to the one you have. This after they confered with a Ford Dealership parts guy. I'm still a bit skeptical..... We'll see when i go pick it up.
F350JOHN
266
02-28-2024 05:32 PM
Rocky Mountain F150
07-02-2016 09:34 AM
colo_dually
06-18-2011 10:10 PM
Steeler Fan 4 Life
1997-2006 Expedition & Navigator
01-28-2011 11:28 AM
Quick Reply: Oil Filter Adapter
