lets see the supercabs!!!
#451
Received 5,149 Likes
on
#452
My new SuperCab Australia
Hey, after always wanting a fit ruck if finely got one. This is my f250 SuperCab ranger. Does anyone know who owned this truck before me?
Also could you recommend a good offset to run on a new set of 16x10 rims? Looking to run 35' or 37'
And lower it a bit
Thanks
Also any f250 Facebook groups in au??
[IMG][/IMG]
And lower it a bit
Thanks
[IMG][/IMG]
#454
#455
Congrats on your supercab. Looks good.
"Also could you recommend a good offset to run on a new set of 16x10 rims? Looking to run 35' or 37'"
I'm running 16.5X9.75 with 4.5" backspace (-20mm offset?) 35X12.5 tires. I have about 2.75" clearance at full lock from the pitman arm. Gives the truck a nice stance IMO. If you keep some lift you should be ok with 37"
"And lower it a bit"
Lifted is great for rock crawling.... A PITA if you want to throw a bale of hay in the back.
#457
My truck only has a leaf added to the front. That brought the front up about 2.5 inches, enough to level out the truck and provide clearance for the 35's.
Running a 460.
#458
on
#459
#461
#462
#464
