Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-16-2008, 06:00 PM
Sweet Christine Sweet Christine is offline
Garage is empty, add now
Sweet Christine is starting off with a positive reputation.
97 F150 4.6 Spark Plug Change-Difficult?
Here's the situation: a '97 w/69k & 4.6 thats never had the plugs changed. They look buried in the engine compartment. I'm very apprehensive about tackling this project. Any special tips or things that I should be cautious about ? Or is this not as bad as I think?
  #2 (permalink)
Old 03-16-2008, 06:26 PM
bowdog bowdog is offline
bowdog is starting off with a positive reputation.
If the truck isnt missing, I wouldnt change them....the gactory plugs and wires are good for 100,000miles.
If you do have to change them.....the 4.6 isnt nearly as bad as the 5.4. however, with some patience and a good set of sockets and extensions, you should be able to handel it. Once you loosen the plug, use a peice of tubing to screw the rest of the way out and to lift out of the hole.
there is a very good step by step instruction sheet on this web. Just do a search
Goodluck
Bowdog
__________________
1998 F150 XLT 4x4 4.6 Liter
Dynomax Catback Exhaust, Dual Exit Out the Rear
Alpine HeadUnit with 4 Polk Audio 6x8
Tonneau Cover
107,000 Miles
  #3 (permalink)
Old 03-16-2008, 06:44 PM
zman764 zman764 is offline
zman764 is starting off with a positive reputation.
I didnt read that instruction sheet, but I used a combo of 2 or 3 extensions & upto 2 ujoints.
I spent about 2 hours doing it for the first time. Its not as bad as it looks, just have some kind of cushions you can lay on, im 6' & w/ my 33" tires on my 4x4 97 I had to literally lay accross the engine bay to get the back ones.
G/L
__________________
'97 4x4 4.6 230k miles
November 19th 2009
  #4 (permalink)
Old 03-16-2008, 07:56 PM
4.6 spark plug change
Goodluck
Bowdog
I read the instructions. Looks like an all afternoon project. How long before the next change? By the way, the truck runs great - no engine miss at all.
  #5 (permalink)
Old 03-17-2008, 08:27 AM
If the truck is running good.....dont worry about the plugs and wires....they are good for a 100,000 miles.
if you want, pull the plugs and look and see how they are burning...reset gaps ect.
Goodluck!!!
Bowdog
__________________
Tonneau Cover
107,000 Miles
  #6 (permalink)
Old 03-17-2008, 09:03 AM
ground_zero298 ground_zero298 is offline
ground_zero298 is starting off with a positive reputation.
with that many miles and not being done before, after I pulled the boots I would use air to clean out where the sparkplugs go, just incase any dirt or small stones have worked their way down their. Also make sure the engine is hot. If they won't break loose just stop and put it back together and pay fords to do it.
  #7 (permalink)
Old 03-17-2008, 04:19 PM
Octane's Avatar
Octane Octane is offline
Ninja Commando From Hell
Octane is starting off with a positive reputation.
At 69,000 miles I wouldnt be worrying about it. I would wait until 100,000 miles to change them.
When you do change them, you want to get a special sparkplug socket that had a sparkplug boot inside of it. That will hold the sparkplug inside the socket and will make the job much easier.
Its not all that hard of a job to do, but it does require some patience. Most important of all, make sure that you let the engine sit overnight before you remove the sparkplugs. The cylinder heads are made of of aluminum, so its easy to strip the threads. If you let the engine cool completely by letting it sit overnight, it will lessen the chance of stripping the threads.
__________________
'99 Ford F-150 regular cab longbed 4x4 Off-Road with 5.4L V8
190,000 miles
Support USA manufacturing!!!
Earth first. We'll worry about logging the other planets later.
  #8 (permalink)
Old 03-17-2008, 06:20 PM
Thanks for the plug changing advise. Everyone agrees to sticking with the Motorcraft brand spark plugs, right ?
Has anything ever worked better ?
Anything else I can do to improve fuel economy besides the usual filter changes, etc, ?
  #9 (permalink)
Old 03-17-2008, 08:53 PM
Stick with double platinum moto craft or autolite. (there's pages of pages of flames on here about autolites not being as good or w/e ... but its a freaking spark plug i honestly dont even remember which i put in mine just w/e auto zone or advanced had.) Im not sure why people want you to let the truck sit over nite.... it only takes 2 hours or so max for an engine to cool completely... as long as its not hot enough to burn you it should be fine. Put anti-seize on the threads when you put them in. Usual filter changes including your inline fuel filter. Clean the little electrode behind the airfilter... At only 69k miles your truck is still brand new mines got 217,200 miles on it
As others have said if your trucks not knocking leave it alone until 100k or until you notice a decline in responsiveness or fuel economy.
If it aint broke dont fix it.
__________________
November 19th 2009
  #10 (permalink)
Old 03-17-2008, 10:21 PM
Thudpucker's Avatar
Thudpucker Thudpucker is offline
Thudpucker is gaining momentum as a positive member of FTE.
Mine finally failed (#3 misfire) at 136,000 and I paid to put the platinmum plugs in. The truck is going up onto 195,000 now and still running very well. I sold it to a neighbor.
__________________
97 F-150/4X4/ex cab/4.6V-8/auto/Lariat,F/Glass canopy and a 77 F-150/460/C-6/ex-cab/Fglass Canopy.
  #11 (permalink)
Old 03-17-2008, 10:55 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Changing the plugs and wires are a royal PITA! I spent 8 hours changing 7 plugs and wires about 2-3 months ago. I still have to do #4...the hardest one to get to. Whoever designed these trucks need to be shot...
__________________
-2007 Dodge Ram 2500 4x4
-1988 F350 4x4 7.3L IDI
-1978 F150 4x4 - 466ci/4-spd/1-tons
  #12 (permalink)
Old 03-18-2008, 08:29 AM
Spotty Spotty is offline
Spotty is starting off with a positive reputation.
The plugs are probably fine, what concerns me is the amount of time they have been in the head. That is a lot of heat-cool cycles. I would change them just to get them out of the heads, put new PP plugs in, with a little anti-seize, I also put a very small drop of oil on the threads, and work the anti-seize and the oil into the threads. You can then forget about it for 100,000 miles, knowing they will come out OK if you still own the truck. The only real harder ones are back by the heater hoses, use a bungee cord and wrap it around All the hoses, wires etc... and gently pull them toward the fender and hook off. Be sure to pull the negative battery cable. Also back in that corner, it will be easier on one of them to unplug the injector electrical connector (easy to do). Be sure to blow out the holes before you start, if you don't have a compressor buy a can of compressed air like for your computer. Pick up a small packet of dielectric grease and put a dab on the end of the boot before you plug them back on. I use the spray stuff and spray into the boot, all slips right on, easy to get off in the future. If you have a plug that is coming out "stiff", stop and spray a little WD, PB... whatever... down the hole wait a few minutes, walk the plug back in a turn, then remove it. Will come out like butta'. As with any aluminum head, should work on it cold.
Your question on fuel economy, the guys covered it, may I add... to clean your MAF sensor, best 30 seconds you can invest.
Good luck and have fun with it, it's really not bad at all.
Spotty..
__________________
98 Ford F-150.4.6.4x4. Extended Cab 8' Box
2000 Mustang Gt, Black on Black, 100% stock
  #13 (permalink)
Old 02-01-2009, 08:45 PM
nickellis_21 nickellis_21 is offline
nickellis_21 is starting off with a positive reputation.
i have hurd that its best to use ACDelco plugs and if you buy the wires and they dont have a name brand printed on the outside of the actual wire dont buy it its not a good wire
  #14 (permalink)
Old 02-01-2009, 09:27 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a good reputation on FTE.steve(ill) has a good reputation on FTE.
if you have a 5.4 you better use the Motorcraft plugs to get best performance. Many guys have had trouble with other brands in the 5.4
__________________
2002 SuperCrew 4 x 4 5.4 XLT -100K miles -NEW
2010 EDGE FWD - V6 ----------30,000 miles
2002 Explorer 4 x 4 4.0 XLT --- 162,000 miles
2001 SuperCrew 4 x 4 5.4 XLT -235K miles -GONE
  #15 (permalink)
Old 08-13-2009, 10:52 AM
gastonf150 gastonf150 is offline
gastonf150 is starting off with a positive reputation.
I guess by now you have done the plugs in your 4.6. From reading all the information on this blog, with the exception of taking 8hrs, I found most hints useful. using a bungee to keep the hoses off the passanger rear, Nice. Letting it cool a bit, Nice. Patience is a must have. I kept hearing how hard #4 was to get to, not really that tough considering how it looks.
One thing I did come up with was to use the tubing along with a phillips head screwdriver to take out the loosened and insert the new plugs coated with antiseize. Slide the tubing most of the way up the screwdriver while allowing an inch or so to hold the spark plug. This kept th tubing straight. I had a clear tube remnant that was snug enough to turn the plug into place before using the socket to completely tighten it. Good luck
Tags
1997, 1998, 46, 97, change, cylinder, f150, ford, head, plug, plugs, problems, recommended, removing, spark, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
