Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-02-2001, 10:43 AM
bubbaf250's Avatar
bubbaf250 is starting off with a positive reputation.
351M pinging like crazy!
__________________
1980 F250 4x4 Custom, 351M/NP435/NP208/D44HD-TTB/D60-FF
FTE Moderator
Please support FTE. Visit the online store.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-20-2001, 10:53 PM
beratte is starting off with a positive reputation.
I have a 79 F-150 with a 351M with an Edelbrock intake and 4 barrell. When she gets hot she pings like crazy. Anyone have this problem with this engine? Thanks
__________________
Best of luck, Ben
95 Bronco XLT, 302, E4OD, 31" BFG AT's
  #3 (permalink)
Old 02-21-2001, 12:31 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
Most likely it is overheating.
__________________
Dave F
1989 F250 XLT Diesel
  #4 (permalink)
Old 02-21-2001, 10:45 AM
Bill_Beyer is starting off with a positive reputation.
>engine? Thanks
First thing I'd check is the timing. Second thing is to make sure the EGR system is functioning properly if it's still there. These engines were designed to function with EGR so taking it off can have a detrimental effect on the performance. You may have to retard the timing more and/or go to a higher octane fuel if you've pulled the EGR off.
  #5 (permalink)
Old 02-21-2001, 01:37 PM
bubbaf250's Avatar
>the EGR off.
Or enrich the A/F mixture to compensate for the missing EGR. The purpose of EGR is to reduce NOx emissions produced by over-lean mixtures.
Check the base timing and also the vacuum advance. Ford vac advances are adjustable with a 1/8" Allen wrench in the vacuum nipple. To reduce vac advance sensitivity, turn the screw counter-clockwise. (Some aftermarket vac advances work the opposite way, though.)
BubbaF250
1980 F250 4x4 Custom, 351M/NP435/NP208/D44HD-TTB/D60-FF/3.55s 6750 GVW, Rust & White.
__________________
FTE Moderator
  #6 (permalink)
Old 02-21-2001, 02:01 PM
Yep no question a lean mixture will cause a hot engine and increase the tendency to detonate.
  #7 (permalink)
Old 02-21-2001, 05:51 PM
thanks all, I'll start with checking the timing. I'm not sure if the Edelbrock intake and carb retained the EGR, I'm thinking not.
__________________
Best of luck, Ben
  #8 (permalink)
Old 02-27-2001, 10:33 PM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
[font size="1" color="#FF0000"]LAST EDITED ON 27-Feb-01 AT 11:35*PM (EST)[/font][p]I had a 400 C that was bored out and did the same thing. Especially when the outside temp rose. Installed some splitfire plugs. Eliminated 99.9% of the problem. Only when it was 100+ outside, then I needed to run premium fuel. I messed with timing and had no effect. Nothing worked until the plugs were installed.
I did keep mine all stock except for the oversize pistons on a 2 barrel carb.
That's my experience with it.
98 F250LD 4X4
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
