Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-16-2008, 11:12 AM
cbruns9 cbruns9 is offline
Garage is empty, add now
cbruns9 is starting off with a positive reputation.
Schrader Valve on Fuel Rail
Hello all,
I have a 2002 4.2L F150 (140k miles). Is it possible that there is not a schrader valve on the fuel rail? I am assuming it is on the left (passenger side) in the engine compartment but I can't seem to find it. I can see two that I believe are for the Air Conditioner, but do not see one for the fuel line. I've looked at manuals (Haynes) and even a drawing from a 2002 shop manual but no luck in finding it on my engine. I would like to change my fuel filter and would rather relieve the pressure using a fuel guage and run off than disconnecting fuses or using the inertia switch. Thanks in advance for any help.
  #2 (permalink)
Old 03-16-2008, 01:44 PM
superdutymj's Avatar
superdutymj superdutymj is offline
superdutymj is starting off with a positive reputation.
you can just pull the fuse for your fuel pump and turn your truck on till it dies, then it will be depressurized. The shrader should be on your passenger side fuel rail towards the back, over the second cylinder i believe.
__________________
-2005 F-150 Scab 4x4 5.4 XLT. Leveling kit, grille guard Reflexxion cowl induction hood
-1994 D3500 dually. 12v cummins. 4" straight pipe, BHAF, modded P7100. Marine Injectors.
-1995 F-350 SRW 2wd 460 5spd CrewCab Longbed XLT. "Short-Timer"
  #3 (permalink)
Old 03-16-2008, 02:32 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I never touch them after I relieved pressure on a 460 and the damn thing started leaking afterwards. Pulling the fuse and starting the truck is the only way I do it now.
__________________
'51 F3 Flat8
'64 Galaxie 352 4bbl
'72 F250 400/C6
'01 CVPI
'97 F150 5.4L
'09 F150 5.4L
  #4 (permalink)
Old 03-16-2008, 04:07 PM
Thanks for the advice. I will pull the fuse and start the truck. I appreciate your help.
  #5 (permalink)
Old 03-16-2008, 05:02 PM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Either pull the fuse, or unplug the crash sensor. Its a black box thing in the passenger side kick panel.
__________________
-Gone with the 250,000+ '98 F-150
-2002 FX4 Lariet F-150
-5.4/4r70w, 3.55LS, 130,000m
  #6 (permalink)
Old 03-21-2008, 09:12 PM
Just a quick update. I changed my fuel filter ($12 motorcraft) today. I pulled the fuse (#10), cranked the engine (no start), jacked the truck, and replaced the fuel filter (with $8.00 tool from Harbor Freight) all in about 10 minutes. I am good to go for another 15,000 miles. Thanks to the forum for your help, I really appreciate it. For anyone else debating about changing their fuel filter themselves, I say go for it! The job is easy and you can save some money. Thanks again for the help.
  #7 (permalink)
Old 03-21-2008, 09:18 PM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
If it's a returnless system(which I don't think this year was), your not going to have a schraeder valve. The fuel rail will have a pressure sensor that the pcm can read rail pressure off of.
__________________
If it ain't broke.....change stuff till it is!
Ford Dealership Tech...
Ford Diesel Apprentice...
  #8 (permalink)
Old 03-21-2008, 10:44 PM
nope, it has a schrader valve. so do the new ones. returnless systems were on early carb systems.
__________________
  #9 (permalink)
Old 03-21-2008, 10:46 PM
ford doesn't use returnless systems is what i'm getting at, and regardless of the "type" of system used, it will have a schader valve on it, which is only used to check the fuel pressure and volume, the vehicle itself doesn't use it for any purpose.
__________________
  #10 (permalink)
Old 03-21-2008, 11:27 PM
wolfman01 wolfman01 is offline
wolfman01 is starting off with a positive reputation.
The schrader valve was pretty well hidden on my truck, and it has the 4.6 engine. I would assume that the 4.2 is buried even deeper into the engine compartment, making the valve a tougher find.
__________________
1994 Safari Sarengeti Edition, 92k
1989 Nissan Hardbody truck (69k)
1997 Ford F150, 168K (for sale)
2008 Chevy Impala 2LT (23k)
  #11 (permalink)
Old 03-21-2008, 11:46 PM
well it's got to be on the fuel line that's connected to the fuel injectors, so it shouldn't be that hidden
__________________
Tags
01, 1991, 1999, 2000, 2006, 97, add, f150, ford, fuel, located, rail, schrader, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
