08's???
Old 03-16-2008, 10:59 AM
lazerf250's Avatar
lazerf250
lazerf250 is offline
08's???
I was curious if you can run the new 08 powerstrokes and duramax's off of biodiesel?
Old 03-16-2008, 11:02 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Ford and GM say yes..........But no more than B-5 or you will void the warranty.
Old 03-16-2008, 11:08 AM
lazerf250's Avatar
lazerf250
i was curious about b100, just if it will run fine with all the egr and stuff dont care bout the warranty. do you know if gmc has the same b5 warranty thing?
Old 03-16-2008, 11:55 AM
fabmandelux
I haven't found any studys on the 08's but I've met 2 guys that use B-100 in there 07's with 0 problems. Yes GMC only recomends B-5..........
Old 03-17-2008, 06:09 PM
6.0superduty's Avatar
6.0superduty
6.0superduty is offline
My buddy runs B100 in his 07 Dmax and he said the only thing he had to do was replace the lift pump because of some sensor or something didnt like the bio. Other than that, it runs fine.
Kyle
Old 03-18-2008, 08:21 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Guys it is time to repeat this again.
The B5 recommendation comes from EMA (Engine Manufacturers Association) and stems from the lack of ASTM standards for BioDiesel. It is not the truck makers that set the max percent at 5%, they were following industry guidelines.
The reason B5 was chosen is because if the BD meets the standard for use in blending at the 5% level the blended fuel still meets the standard for #2 diesel.
As ASTM gets closer to finishing the standards for higher percentage blends you should see those percentages rise, it is already happening in some industrial use engines.
Old 03-18-2008, 10:27 AM
tazo's Avatar
tazo
tazo is offline
http://www.biodiesel.org/resources/f...arranties.shtm
http://www.biodiesel.org/pdf_files/B...ment_32206.pdf
Here is everything you ever wanted to know. Grab a recliner and a pot of coffee and enjoy the read.
08F1Tizzy
2004 - 2008 F150
02-14-2012 05:01 PM
flyboy5111
06-15-2009 09:07 PM
F-250beast
1999 to 2016 Super Duty
01-22-2009 04:41 PM
Super08
13
09-07-2007 02:03 PM
Louisville Joe
Modular V10 (6.8l)
03-17-2007 10:26 AM
Quick Reply: 08's???
