Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-16-2008, 01:05 AM
buckrogers is starting off with a positive reputation.
Red face water flow
I recently had the engine rebuilt in my '66 F100, I noticed that I need to add fluid to the radiator from time to time. I was wondering if I should be able to see the water flow in the radiator when looking into the radiator. I replaced the cap because it looked pretty old and I don't see any leaks. Does anyone have any ideas where I may be losing water ?? I also noticed that the upper hose blows up like a ballon when the engine is hot, the gauge shows that the engine is not over heating and the thermostat was replaced with a 190. The engine was bored 30 over, I was told that the "new" engine will use a little oil and water until it's "broke in". Anyone have any feedback on this "problem".
Thanks in advance as always.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-16-2008, 04:08 AM
ReAX's Avatar
Molon Labe
ReAX is gaining momentum as a positive member of FTE.ReAX is gaining momentum as a positive member of FTE.
That sounds bad to me. the gaskets should be firmly seated as the bolts were torqued down. You may want to double check that the bolts are properly torqued.
I've never seen flow in the radiator, but it's a pretty nice place to watch for air bubbles. If your heads are leaking exhaust into the coolant, the bubbles will float to the highest point. If exhaust is flowing into the coolant system then it's possible while under pressure(hot) that coolant would flow back in to the cylinders. If it's going into the oil, you should see the oil turning white. Out the tail pipes, oil is blue and coolant is white smoke.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
