86 460 specs - Ford Truck Enthusiasts Forums
86 460 specs
Old 03-15-2008, 07:07 PM
gilllawn gilllawn is offline
gilllawn is new and has a neutral reputation at this point.
86 460 specs
I have an 86 460 carbed and I wanted to know what specs are available. Specifically what the RPM power range is. I have a C6 auto tranny behind it and the engine idles at 1000, and the C6 I believe has three (3) gears in it so at the top gear around 65MPH it runs around 5000 rpm. Is this normal? This is my first big block ford that's why I'm asking. Biggest prior to this was a 302 and that motor would be screaming.
Thanks
Old 03-15-2008, 09:34 PM
scottddove's Avatar
scottddove scottddove is offline
scottddove is starting off with a positive reputation.
I have a 86 460 with a c-6 also. I am running 35" tires with I think 373 gears and I am doing maybe 3000 at 65 probably a little less actually. 5000 is screaming that doesnt sound right to me.
Old 03-15-2008, 10:03 PM
I picked up a tack from a junk yard so It's quite possible that it does not work quite right. I thought it was a little off myself. The engine is not screaming though.
Old 03-16-2008, 12:10 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
You need to get the rear end ratio. My 1984 460, C6 with 4.10 rear end runs at about 3400 at 65 mph but I never run faster than 58 mph because gas mileage pretty much dies after that.
Question about idle and driving rpm 6.0Lover 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 03-20-2015 08:46 PM
need timing specs 302 jd4300 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-11-2010 09:53 PM
1991 460 Engine Specs OrangeJuice Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 09-23-2009 11:03 PM
Building a 460 for my pulling truck The Freak Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 03-22-2006 10:42 PM
351c specs scottjohn Performance & General Engine Building 2 09-22-2002 01:06 AM
Tags
1984, 460, 86, engine, ford, head, spec, specs, troubleshooter, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
