help, 99 f250 7.3l cylinder 3 and 4 dead - Ford Truck Enthusiasts Forums
Old 03-15-2008, 07:06 PM
Krupka Krupka is offline
Krupka is starting off with a positive reputation.
99 f250 7.3l with 200,000 miles. cyl 3 and 4 are dead and has alot of blue smoke.
I ran the injector buzz test and all buzzed and sounded good. I ran the cylinder contribution test and cylinder 3 failed. I replaced the cyl 3 injector, and test drove it. The truck still had a missfire. So i ran the buzz test again and code p1668 (IDM EF circuit failure) came up. A few minutes later i ran the buzz test again and the code would not come back. I ran the contribution test again, and cylinder 3 and 4 failed. I guess i am leaning twards the IDM but any known problems or advice would be great. Thanks in advance.
Old 03-15-2008, 07:59 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
I believe the buzz test only tells you that there is power to the injector, not if the injector works. Have you installed the new CPS (gray one) yet? There are problems with it more likely with #8, but it could be the problem you have. Disconnect the batteries for a while to clear things and then hook them up and test it again. What are you testing it with?
Old 03-15-2008, 09:10 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
Tenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud ofTenn01PSD350 has much to be proud of
Why are you leaning towards the IDM? Does not say faulty IDM.
<table border="1" cellpadding="3" cellspacing="0"><tbody><tr><td align="center" valign="top">P1668 </td> <td align="center" valign="top"> </td> <td align="center" valign="top">PCM/
IDM </td> <td align="left" valign="top">PCM/IDM diag. communication error </td> <td align="left" valign="top">Open/shorted EF or FDCS wire, open IDM grd.</td></tr></tbody></table>
Old 03-16-2008, 11:18 PM
look through the pinpoint test and you will see that it could be wiring, pcm, or IDM
Old 03-16-2008, 11:20 PM
And the crank position sensor is not going to give me 2 dead cylinders
Old 03-16-2008, 11:47 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Quote:
no, but a chaffed under valve cover harness will.
Cylinder 8 contribution fault BRay09 1999 - 2003 7.3L Power Stroke Diesel 11 07-24-2014 11:33 AM
injector buzz test question.. Monkeys7.3 1999 - 2003 7.3L Power Stroke Diesel 14 04-18-2013 03:46 PM
Smoke Problems ccg711 1999 - 2003 7.3L Power Stroke Diesel 63 03-20-2011 10:58 AM
buzz test all failed?? mrblonde108 1999 - 2003 7.3L Power Stroke Diesel 7 09-19-2010 01:11 PM
Dead cylinder and fuel knock 87redtempo 1994.5 - 1997 7.3L Power Stroke Diesel 1 08-02-2010 01:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
