351M/400 - Ford Truck Enthusiasts Forums
351M/400
Old 04-04-2001, 07:44 PM
Nathan Nathan is online now
Nathan is starting off with a positive reputation.
351M/400
Old 04-08-2001, 09:06 AM
tbolt 460's Avatar
tbolt 460 tbolt 460 is offline
tbolt 460 is starting off with a positive reputation.
351M/400
I need a C4 bellhousing and or trans from a 77-79 351/400 working or not for my 460
Old 04-08-2001, 12:55 PM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
351M/400
Did they even make a C4 with the big block bellhousing bolt pattern?
Old 04-08-2001, 01:16 PM
tbolt 460's Avatar
351M/400
the 351M/400 has the same bellhousing bolt pattern as the 429/460
I have a C6 in my car now and its a little big,plus the C4 weighte less.I only need the bellhousing from the 351M/400-C4,but if someone has a trans and bell working or not i would be interested
Old 04-08-2001, 01:45 PM
Bill_Beyer's Avatar
351M/400
I'm aware the 385 and M series have the same bellhousing bolt pattern which is why I was asking if Ford ever put a C4 behind a big block.
Old 04-08-2001, 01:48 PM
tbolt 460's Avatar
351M/400
not that i know of
Old 04-09-2001, 12:13 AM
ecarter50 ecarter50 is offline
ecarter50 is starting off with a positive reputation.
351M/400
Try ebay I have seen several of them like the one below.
http://cgi.ebay.com/aw-cgi/eBayISAPI.dll?ViewItem&item=569874979
Old 04-16-2001, 11:55 PM
mhmcgyver mhmcgyver is offline
mhmcgyver is starting off with a positive reputation.
351M/400
C/6 IS THE ONLY TRANS FORD EVER PUT BEHIND ANYTHING 351CID OR BIGGER. OTHER THAN FINDING A GOOD FMX TRANNY{AND SOMEONE WHO CAN ACTUALLY BUILD IT RIGHT}YOUR STUCK AS FAR AS AUTO'S GO.I MAY BE WRONG,BUT I'VE NEVER HEARD OF A C/4 WITH A 385 SERIES BOLT PATTERN.
Old 04-17-2001, 01:39 AM
xaviar's Avatar
xaviar xaviar is offline
xaviar is gaining momentum as a positive member of FTE.
351M/400
[font size="1" color="#FF0000"]LAST EDITED ON 17-Apr-01 AT 01:51 AM (EST)[/font][p]I parted out a 79 F150 with a 351M with a C4 transmission. It's called a High Pressure C4. I'm not sure how long this trans was used or made but, Ford did make such a animal. It will bolt behind a 385 series BB. As far as I know and found, it has never been used behind a 429/460 and does share the same bolt pattern as the 335 series per Tbolt460 statement.
It is now being used in my 71 Mach with a 514 stroker soon to be equipped with a Gear Venders Trans.
Xaviar
96 F-250HD 4x4 460/E4OD 4.10
Banks Power Pack, Banks Trans Command
MSD 8227 Coil, MSD 32199 8.5 Wires, MSD 6A
Old 04-17-2001, 03:10 PM
Bill_Beyer's Avatar
351M/400
[font size="1" color="#FF0000"]LAST EDITED ON 17-Apr-01 AT 03:10 PM (EST)[/font][p]>I MAY BE WRONG,BUT
>BOLT PATTERN.
Gee that one on eBay must be a figment of our imagination.
Old 04-17-2001, 04:50 PM
tbolt 460's Avatar
351M/400
what is so hard to understand,the 351/400 has the 429/460 bellhousing bolt pattern with a C4 trans on it!!.The 351C has the small block pattern.What about the one on ebay!Thats what u need to put the C4 on a 460. 10-4
Old 04-17-2001, 04:53 PM
tbolt 460's Avatar
351M/400
the transmission does'nt have the 460 bolt pattern, the bellhousing does
Old 04-17-2001, 11:46 PM
351M/400
gee bill, i guess you actually looked at the picture of "THE FLAIR CASE". GOOD GRIEF!
Old 04-18-2001, 03:10 AM
tbolt 460's Avatar
351M/400
what transmission was used behind the 351/400? The FMX or C4.Can the bellhousing Be taken off the FMX like the C4 can?
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
208, 351m, 400, c4, gearvenderstrans, putting, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
