Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 03-18-2008, 12:23 PM
matt2491's Avatar
matt2491 is new and has a neutral reputation at this point.
RCA, I'd just like to clear up a quick question.
When the light bulb is NOT illuminated, it means that the points are closed, correct?
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 03-18-2008, 03:09 PM
RCA78SS is starting off with a positive reputation.
timing
No...points closed = illuminated
points open = no light, but this is when the saturated coil collapses and produces the ignition spark.
  #18 (permalink)
Old 03-18-2008, 04:54 PM
matt2491's Avatar
Ohh, I see. So when the points are open for that split second, that's when the spark is produced?
  #19 (permalink)
Old 03-18-2008, 05:09 PM
matt2491's Avatar
Also, my '64 F100 shop manual says that the recommended BTDC timing degrees should be at 6. From there it says that I could advance it up to 5 degrees more, but past that there wouldn't be any more gain. Just keep going past 6 until spark knock is heard, then just back it off a little. Sounds good!
I'll go try this out right now. Thanks again guys.
  #20 (permalink)
Old 03-21-2008, 09:20 PM
kotzy is starting off with a positive reputation.
RCA I think you have it backwards, since current follows the easiest path to ground the light is not illuminated when the points are closed. It is when they open that the light lites, and that is when the spark occures. That was the way the old timers timed engines, I worked with two of them in 1952/3 and while that Sun timing light was there they wouldn't pick it up. A couple of young guys thought they couldn't be accurate doing it that way. Lets say we had a lesson eating crow. kotzy
  #21 (permalink)
Old 03-22-2008, 11:16 AM
matt2491's Avatar
Okay, so did I mess it up by clamping down the distributor when the light was OFF?
  #22 (permalink)
Old 03-22-2008, 11:18 AM
matt2491's Avatar
Also, I have a quick question:
To 'retard' the timing means to increase the degrees before TDC, correct? Yes/no.
  #23 (permalink)
Old 03-22-2008, 01:08 PM
46yblock is starting off with a positive reputation.
To advance the ignition you relatively increase the degrees BTDC, to retard ignition decrease the degrees BTDC. Maybe it would be easier to borrow a timing light from a neighbor?
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #24 (permalink)
Old 03-22-2008, 03:21 PM
matt2491's Avatar
Well, that's the other thing. I had to use a piston stop to find TDC because the harmonic balancer had slipped a bit over the years. From my newly discovered TDC I did RCA's method of static timing. I've tried timing lights but for some reason they don't flash correctly or I set it up wrong...
Thanks for clearing up the advance/retard query, I was thinking of it backwards due to semantics.
  #25 (permalink)
Old 03-24-2008, 08:44 AM
Kotzy:
I think I'm correct. Current flows throgh the closed points contacts when they are closed = illuminated bulb.
  #26 (permalink)
Old 03-24-2008, 01:14 PM
Y-Blockhead is starting off with a positive reputation.
RCA78SS
You are exactly correct, points closed, current flows through coil and points (light on), points open, collapses coil magnetic field and BAM we have fire!!
Y-Blockhead
  #27 (permalink)
Old 03-24-2008, 02:07 PM
matt2491's Avatar
Sorry, I'm still just a little confused. Could someone just answer this question:
Do I want to clamp down the distributor when the points are OPEN or CLOSED?
_____
Also, I just installed a Pertronix module and coil I had. Will this static timing method with the bulb still work?
  #28 (permalink)
Old 03-24-2008, 03:00 PM
I’ll try. I think everyone is in agreement that the plugs fire when the points open??
So I have tried to simplify it by removing the light bulb from the equation and use #1 spark plug to indicate when it fires.
This is what I did to static time my 312 with Pertronix
Set crank shaft timing mark at 6 deg BTDC (set to what you desire, I set mine at 10, but I have a built engine)
Adjust air gap on Pertronix pick up. Use brass feeler gauge included in the kit.
Turn distributor counter clockwise so pick up and magnet are not lined up.
Pull #1 plug and connect to #1 wire coming from distbutor cap and ensure plug is grounded.
Connect all wires to and from coil, distbutor, ignition switch, etc.
Turn on ignition switch and slowly turn distributor in clockwise direction until spark plug fires.
Without moving distributor, tighten clamp.
You are now timed at 6 deg BTDC or pretty dang close. Close enough to start anyway.
But if your balancer has slipped, all of the above is a moot point until you replace it.
Clear as mud right.
Hope I was of a little help
Y-Blockhead
One last point, make sure the coil you are using is compatible with the Pertronix or bad things could happen.
You may want to use the points and condenser to get it running then change to the Pertronix later. The points system is the most basic and has worked for a long time, maybe even before I was born, ha,ha.
Good luck to you.
  #29 (permalink)
Old 03-24-2008, 04:04 PM
matt2491's Avatar
Alright, that did help quite a bit actually. Thanks a lot Y-Blockhead. I also installed a Flamethrower coil with the Pertronix I pick up.
I heard that if I leave the ignition on for too long the Flamethrower coil and Pertronix Ignitor can burn up. How long is too long? I mean... in order to test this thing, I need to turn on the ignition but not start the motor...
I can see why visually seeing the spark is the best way to go because it is the most accurate to lining it all up with the timing degrees marks.
Thanks again!
  #30 (permalink)
Old 03-24-2008, 04:23 PM
Matt, glad I could help. Don't know how long is too long for the Pertronix, that's why I suggest you put the points back in to try it out and get some "practice". I have never had a problem with a pertronix in the last 8 years I've been using them but I know peole that have. I really don't think I want to find out how it would take to fry one but I will admit that I "forgot to turn off the switch once... but I also have a different setup, I only use the Pertronix to trigger a MSD 6A. You want too see a hot multiple spark...
Best of luck,
Y-Blockhead
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
