Welcome to FTE. Pud, I don't have a 4X4. at least I'm assumeing that you do just by the code. I think that the guys on this forum can be of a greater assistance to you if you will supply more information ie year, model, any mods, mileage, is your truck chipped, last oil change, what you were doing when you got the CEL, have you cleared the CEL to see if it came back, etc.
Put all of that together and I'm sure that someone will get back to you with a fix.
ah, ok, no chips, besides the 1280 is electrical, 1211, 1212 is more of a demand problem. check for corrosion and connector problems, if thats ok then you need a scan tool that can check pid data to see what the icp is reading, its probably a bad sensor or the connector itself
