Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 03-14-2008, 07:59 PM
Forest Beast is starting off with a positive reputation.
6 inch lift 38 inch tires
I have a 2002 Ford Excursion with a 6 inch Superlift and 35" BFG AT's on 17x10" wheels. I have a lot of room between the tire and fender and I'm sure I could fit 37" tires but I would love to squeeze a set of Pro-comp 38.5x14.50 XAT's. The spot I worry about is the bottom of the front bumper, I wonder if I could space this out to get hte clearance. Just curious if by some chance somebody is running 38" tires with a 6 inch lift.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-14-2008, 08:14 PM
i eat hybrids's Avatar
i eat hybrids is starting off with a positive reputation.
U can run anything basically. It just depends on what you want to cut. Ill post pics and examples in a sec.
__________________
  #3 (permalink)
Old 03-14-2008, 08:18 PM
Now mind you, i dont kno what lift height and tire size these trucks have.
These first couple examples are just to show u what you can do if u cut stuff and have the right spacin on ur rims.
Examples:
Heres some pics of somthing that is more along the line of what your doin:
Any of these setups are possible with alot of cutting of the bumper, the lower valance and the correct amount of backspacin in ur rims.
Hope this helps
__________________
  #4 (permalink)
Old 05-17-2008, 06:22 AM
dslxcur is starting off with a positive reputation.
In the meantime switch back to stock tires
Food for thought ....... bought a 2005 Limited. Has a 6 inch lift with 37x22x13.50 Kumho Road Venture tires....... they look feel and look aggressive..... love them.......but TWO things you should consider A] full lock turn to turn?....these tires rub on the leafs. B] Rack & Pinion gears to a match the stock gear ratio?.... you will lose in the power band performance rpm and enconomy.
If putting back the 37s than 4.30 or 4.56 gears are needed.....I am still researching the lift companies in what they recommend in tire size for their 6" lifts.
Also check out amp power steps for the King.........good luck.....
Do you get tire rub with the 35s?
  #5 (permalink)
Old 05-17-2008, 12:34 PM
BroncoChuck is starting off with a positive reputation.
I have a 02 excusion with 8" lift and 38" tires. They rub a bit if the suspension is cycled while steering. I don't think a 6" lift would be enough without some real trimming.
8" Skyjacker lift with 38" x 15.5 x 20 Parnelli Jones dirt Grips. you see in this pic how close they come to the bumper.
  #6 (permalink)
Old 05-17-2008, 09:37 PM
igotoneforya's Avatar
igotoneforya is starting off with a positive reputation.
Quote:
Examples:
Hope this helps
Where did you find the pic of the black one? I love the look of the wheel wells being filled by tire. I would love to do something similar without more lift. Was this from a website? Give me something...
__________________
03 V10 Excursion Limited 2WD
3.73LS, 6" Fabtech Lift, 35" PC Xtreme ATs
Line X'd Brush Guard and running boards
FM Super 40 w/dual 3" pipes, RAS
11.5+ mpg in town, 13.5+ on the highway
Still miss my 96 Bronco
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
