360 Timing Chain Removal
Im changing the timing chain on my 360. I'm not to familiar with the FE's. I got the harmonic off and got the timing cover off, but how do you get the sleeve off? The cover was a bit ch to get off with that sleeve on, but i got it without damaging it. But how is the timing chain removed? Does that sleeve just slide out or what?
And also what are the timing specs on this motor? Thanks
Put a exhaust pipe clamp onto the sleeve and tighten it tight. Then use a gear/wheel puller putting the pullers jaws on the pipe clamp to remove. The pipe clamp gives the jaws something to hold as the puller does it's thing.
I have to LOL your lucky the timing cover didn't get stuck on the sleeve!! Needless to say you need a new timing cover seal like RMB said!!
Papas66
01-15-2014 10:05 PM
1918ALF
10-05-2013 05:22 AM
FLATFORD1976
08-27-2009 12:10 AM
kodiak55
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
11-07-2005 10:01 AM
